curlesw's Avatar
First time spark plug change
I just finished my first spark plug change…seems to have gone well. I also changed the wires and distributor cap and rotor. I was a little discouraged at first as the plugs on the right side are a pain to get out…should have started on the left side. I did not have the Porsche tool but used a swivel socket as outlined in the 101 Book. I think next time I will buy the tool and give it a try.
Below is a picture of the plugs…not sure if anyone can give me any feedback on the condition. The car ran great beforehand but I’m not sure how long they were in the car…they have at least 18,000 miles on them. The car currently has 102,000 miles.
V/r
Wayne C.
83 SC
Old 01-10-2004, 02:14 PM
curlesw's Avatar
Also, one other question. The old plug wires (original) had an extra wire coming from the distributor and was grounded next to the coil The new wires, Magnecor, did not require...how come? TIA
Wayne C.
83 SC
Old 01-10-2004, 02:49 PM
Make Bruins Great Again
Por_sha911's Avatar
Pardon the hijack but what is "the tool" you use to get the plugs out?
Joe
Old 01-10-2004, 02:59 PM
It'll be legen-waitforit
stealthn's Avatar
Wayne,
What plugs are they? They look a little white, could be fine or could be running too hot (incorrect plugs), and/or too lean. Just my two cents (CDN) as far as original wires if you are talking about the braided ones, these had ground wires on them.
Bob James
06 Cayman S - Money Penny
18 Macan GTS
Old 01-10-2004, 03:02 PM
curlesw's Avatar
13/16 swivel spark plug socket, it has a rubber inset to hold the plug. Do not use just a standard 13/16 socket as the plug will fall out and it's a pain to get the spark plug out. The tool is $10 at Sears. You will also need a 3" extension. However, as noted, I'd try the Porsche tool referred to in other posts...others make it sound much easier.
Wayne C.
83 SC
Old 01-10-2004, 03:04 PM
curlesw's Avatar
Wayne,
Thanks Bob. The old plugs are the same as the new ones Pelican sent me, Bosch Super. The grounds surprised me...just have never seen that before on any of my other cars.
v/r
Wayne C.
Old 01-10-2004, 03:11 PM
Go Speedracer, go!
SpeedracerIndy's Avatar
The ground straps were added by Porsche because they thought that it would prevent air boxes from cracking. At least that's what I have heard. Since the plug wires don't cause intake backfires, and don't cause the air box to crack, you don't need plug wires with ground straps. I also have magnecor wires and am happy with them. See below
1981 SC ROW Coupe
Old 01-10-2004, 03:31 PM
On a great circle route
xlr8's Avatar
Spark plug tool from Porsche tool kit.
Russ
Old 01-10-2004, 03:46 PM
That Porsche plug wrench makes the job extremely easy. What a simple, well-designed tool!
Old 01-10-2004, 03:57 PM
3.2 CAB's Avatar
Sorry to borrow the thread, but speaking about tools, what is the tool that looks sort of like a big eye-bolt?
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 01-10-2004, 04:57 PM
Go Speedracer, go!
I believe it is a tow hook. There's a place to insert it in the front bumper. Someone will have a picture to demonstrate soon no doubt.
1981 SC ROW Coupe
Old 01-10-2004, 05:01 PM
ruf-porsche's Avatar
Actually its for the rear bumper. The front has a tow hook under the pan, but for the rear, on the left side bumper there is a plug, you remove the plug and insert the tow hook.
The Porsche tool is great, but I prefer a 3/8" air rachet, it spins the plug out quickly and you can set it so that it will stop once it hit a pre-determine torque while spinning the plugs in.
Old 01-10-2004, 05:12 PM
3.2 CAB's Avatar
Good to know that, will look for the plug, never noticed one. Thanks.
Newest additions-
others...
Old 01-10-2004, 05:25 PM
Did you back date the heater or did the Euro cars come with the non blower system?
Old 01-10-2004, 07:33 PM
Silveresrty911S's Avatar
Ya they look a little whitish, too hot a plug or too lean of fuel mixture. Wayne, if possible get the original plug tool and check them out after a thousand or two, that tool really makes removal easy.
Rick
Rick
'76 Carrera 3.0, track
'77 3.2 targa, back home
'95 993 C4 M030, SOLD
PCA San Diego
Old 01-10-2004, 07:37 PM
curlesw's Avatar
Silveresrty911S Ya they look a little whitish, too hot a plug or too lean of fuel mixture. Wayne, if possible get the original plug tool and check them out after a thousand or two, that tool really makes removal easy.
Rick
Thanks Rick...that's a good suggestion, I'll make sure to do that. Also, took a look at your Pelican page...nice car. I live on 15th hole at Eagle Crest (San Pasqual)...if you ever play and need a fourth lt me know.
I was wondering the same thing...looks much cleaner.
v/r
Wayne C.
Old 01-10-2004, 08:09 PM
Go Speedracer, go!
The heater was backdated by the PO. I have since replaced the blower motor, but left the right side backdated. I like the clean look of the bay in that pic, but wanted a little heat while sitting at a stop light. With only the left side hooked up to the blower, you don't have the ugly hose going over the top of the fan schroud. I felt that was a good compromise. I need to get a new picture of my new "half backdated" look, but it's just too damn cold out.
1981 SC ROW Coupe
Old 01-10-2004, 09:43 PM
Definitely try to get the Porsche spark plug tool. Its perfect for the job. WIth this thing you can whip all 6 plugs out & out new ones in in ~15mins.
Old 01-10-2004, 10:09 PM
gerard vaglio's Avatar
CDiercks,
Your going to like the Porsche spark plug tool, it makes what you just did so much easier you won't believe it. You'll be changing plugs every week.
Your plugs do look just a little whitish but not bad.
I'm interested in backdating the heat on my 79sc, would you be willing to sell
the left side heat duct that your no longer using?
Gerard
Old 01-10-2004, 10:59 PM
dickster's Avatar
they look fine, just dont leave 'em so long between changes. 10-12k miles is enough for plugs.
Rich
'86 coupe
"there you are"
Old 01-11-2004, 12:28 AM
