I decided instead of a 3.2 I'd go all the way with a 3.6. My mechanic found a solid 92 3.6 with low miles. It's a car that he maintained so while it's still a gamble it's much less of one.
My 3.0 is out and sold...The 3.6 is purchased Anyway I need help 1) While it's not optimal, I'd like to use the SSIs off my 3.0 for a while at least. Is this doable on a 964 engine. I want my heat. This conserves about $2000 that I can put into the suspension. 2) Are there any issues keeping the AC - does the cyntex chip keep you from stalling with a light fly wheel and AC. Thanks Jeff C
Jeff C 76 912E 2.6L |
The SSI's will work w/ a liitle modification, they are too small for best performance.
The stalling issue is over blown. I had a stock 964 chip and a 9# Patrick flwheel w/ no stalling what so ever. Currently I have an even lighter f/w w/ Cyntex chip and no stalling. The heavier Patrick f/w was more comfortable for street use, the car was like a tractor. the lighter f/w requires more feathering w/ the clutch. If you use AC then there may be more of an issue related to that. I dunno about AC.
Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | Last edited by Bill Verburg; 04-03-2004 at 01:04 PM.. |
These have been posted numerous times before, but what the hey,
964 w/ SSI's and home made heat x-over. 964 in a C3
SCWDP- Shock and Awe Dept
Re: 3.6 Conversion underway...need input
Bill has it covered well but here are my thought anyway.
You should be fine on the street w/ SSIs, you will lose a little hp on the top end but I’m sure you will still be happy w/ it. I think a little less hp and being able to do suspension upgrades is a good trade off. Quote:
Jack runs a/c w/ a NBD chip in the stock setting mostly and has no issues that I know of.
Ryan Williams, SCWDP '81 911SC Targa 3.6 '81 911SC Coupe 3.2 #811 '64 VW Camper Bus, lil' Blue |
my car also has the Cyntex chip anf yes for a couple minutes it idles like *****, you need to have him inspect the heads for leaks while the motor is out, the 92 motor doesnt have head gaskets, also you had better hang on to that 2k for suprises, you need some type of oil cooler the 3.6 doesnt have a motor cooler, replace the rear seal adjust the valves, you will want to buy a instant-g kit if your having someone do the conversion to save on hours, the stock air box works but you have to play with it a cone is the easiest, you may think about plugs etc while the engine is out, make sure you have all the part dme harnesses etc, i had a sachs power clutch already and had the disc reworked with a race compound, k9 had a stock clutch and believe he toasted it, the two rubber lines on the fuel line comming from under the car make sure you dont give them away with the 3.0 those fittings are one of a kind, also you should look at widebodies heat tube, that pretty much uses up your spare 2k, Kevin
I believe the 993 engines (maybe 96+ ?) don't have the same stalling issues.
Rob Fusi 77 911S | 3.6 Varioram | Triad Muffler | B&B 9400 Cooler |WEVO everything | Big Reds | 23/33 | 22/22 sways | Polybronze | RSR shocks/struts | FM10s | GTC Motorsports |
Administrator
With AC my 1993 (964) 3.6 idles fine, with the chip in either the NBD position or the stock position.
I think it's smart to put off the big exhaust expense. When I initially did my swap, I put in a Carrera exhaust, with a bypass pipe, and drove like that for a long time. You can get a Carrera setup for about ten cents on the dollar compared to the GHL or B&B setups. It costs you a little hp at the high end, but we're talking about 3.6, here: even with a restrictive exhaust, it's got a lot of power. A few years from now, you can spring for headers, and you'll get a nice little bump in power that you'll be able to appreciate.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 Last edited by Jack Olsen; 04-03-2004 at 12:41 PM.. |
Thanks Guys
Bill - Thanks for the pictures. I know I've seen them before - thanks for the repost. Kevin - I've set aside about $2K (outside of suspension cash) to do odds and ends on the motor while it's out. The '92 engines do have head gaskets. Porsche started putting them in about mid '91. As for oil cooling I'm working on that. I have a large mocal unit in the right fender with screened cut outs in the fender for air flow. I'm deciding on wether to do a left fender unit or center. Jack - Thanks -That's what I was looking for. The been there done that input. At this point the money is better spent other places. Again thanks for the input...I'm sure there will be more questions to come. Jeff C
I know it's less efficient, but I'll probably go with the left fender. I really would like to keep it as stock looking as possible - sleeper kind of thing.
Jeff C
I'm w/ you on that.
My 1990 3.6 , with B+B headers with heat and Timmings muffler, starts and idles just fine with a cyntrex chip .. zero stalling issues ...
Joe |
POVI - Are you running a lightweight flywheel? How about AC?
Jeff C
The idle can be improved by making sure that a) the oxygen sensor and the head temp sensors are good, b) the idle switch on the throttle body engages, c) there are no vacuum leaks and d) adjusting the AFM correctly. If everything is done properly the 964 should idle rock-solid. Some of the performance chips (Cyntex, NBD, etc. ) improve the idle catch for a light flywheel. They increase the RPM level at witch the DME starts to deliver fuel again under decel.
If the engine is hunting a chip wouldn't help. It's most likey the AFM not adjusted properly. Check all the above points or have them checked by a competend mechanic that has worked on 964 and later engines before. Cheers, Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
Hi Jeff
Im running a lightweight flywheel , sachs power clutch with a late 915 ROW 915 trans with limited slip and integraded oil pump and cooler.No A/C. Just for everybodys info ... I did have a hunting idle when i first installed my 3.6 ..ended up being the idle switch contacts on the throttle body was not closing correctly, as Ingo had mentioned above. Fix was just adjusting the switch plate so that when the throtle is at rest the switch contacts are closed on the mico-switch , It can easily be heard with the engine off ..you will hear a distinct 'click' when engaged properly.Symptoms are idle will keep hunting between 900 - 1500 rpm and not settle down. - Joe - |
