kqw kqw is offline
Head Temp Sensor Tool
For those who are interested, the special tool for removing and installing the cylinder head temperature sensor....
14mm 3/8" drive Flare nut socket from Snap-On:
Part# = FRXM14
I did my sensor this evening and it took 1 hour without the tool. If I had the tool, it would have been done in 1/2 hour.
I am ordering the tool to snug up my sensor ( just to check) as I used needle nose pliers on the install.
I will use this tool again in ten years. Anyone wanting to borrow it in the Philadelphia area is welcome.
The Fox
Carrera
Old 05-18-2004, 08:15 PM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
Buy any cheap 14mm deep socket, and grind a slot in it. Works like a charm.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 05-18-2004, 08:23 PM
kqw kqw is offline
ZOANAS....
I tried that and the sockets I had were so tough I couldn't grind a dent into them. What are you using to slot the socket?????
The Fox
Carrera
Old 05-18-2004, 08:26 PM
disc cutter.
206 637 4071
Old 05-19-2004, 07:54 AM
UFLYICU
ZOA NOM's Avatar
I used a Makita angle grinder with a 3" disc. I also used a dremel to smooth it out.
prc-racing.com
Old 05-19-2004, 09:40 AM
Irrationally exuberant
ChrisBennet's Avatar
I just cut a slot in a 14mm box wrench. It's not like I use it for anything else.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 05-19-2004, 09:44 AM
Location: member Central PA Region PCA , Home of the Hershey Swap
Like the others I cut a slot in a Craftsman 14 mm deep socket with my 3.5" Dewalt grinder. The socket was $2 or 3.
regards,
Frequent Pelican Customer
1984 Carrera 3.2 (S. Wong Chip, B&B dual exhaust, Lightened OEM Flywheel, Centerforce Clutch, OEM 930 Rear and Front Sway Away 930 T-bars and sway bars w/OEM susp. bushings,, Turbo Tie Rods, bump steer kit, Adj. Rear Spring Plates, OEM Short Shift, H4s and "City Lights", slotted rotors, 944 Wheels, 225/50/16 and 245/40/16 Dunlop "sneakers," and more
2002 996 TT X50 (H&R Springs)
2002 WRX in WRX Blue
Proud Rennlist Charter Member
Support and Join Rennlist.com
An Expert on absolutely nothin' more than my own opinions!
Old 05-19-2004, 09:54 AM
KTL KTL is online now
Schleprock
KTL's Avatar
I think I used a flare nut wrench. But mine was easy because the engine was on a stand, out of the car.
Kevin L
'86 Carrera "Larry"
Old 05-19-2004, 11:23 AM
I think a flare wrench would be too. It's a tight fit with a somewhat chunky Craftsman box wrench.
-Chris
Old 05-19-2004, 12:15 PM
Photo of the one I made with my Dewalt grinder and a Craftsman 14 mm Deep Socket? Do you think this voids the craftsman warranty?
Old 05-19-2004, 01:30 PM
kqw kqw is offline
All righty then...You folks have convinced me.
I bought a $2.99 14mm deep socket from Sears....My neighbor has a grinder and we'll soon have a special tool.....
Thanks again
The Fox
Carrera
Old 05-19-2004, 02:55 PM
Sears has never voided my warranty for any of the bad ass mistakes i have used their tools for, ever.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 05-19-2004, 03:17 PM
kqw kqw is offline
Hey rbcsaver...
I will cover your warranty...Just return your DAMAGED tool to me and I'll replace it with a BRAND NEW 14 mm socket..OK?????
The Fox
Carrera
Old 05-19-2004, 03:22 PM
