Not Quite Banned
That must be a relief... Call Parts Heaven, they should have one.
Thomas Owen 1972 911T 1972 911S |
alignment
porta-power the lower shock mount until the alignment comes back. You have to go to extreme measures to repair bent Porsches.
Racing Porsche for over 30 years. http://www.OttosVenice.com Check out the Porsche Owners Club Track event Videos |
Senior Member
Re: alignment
Its just a bent part, not a bent Porsche. The t-bar tube, frame, trailing-arm brackets are all in spec. Replace the part, fix the problem.
The rear suspension is from a Carrera and was installed by the PO. It was most likely bent when he installed it. There are no signs of crash damage on the vehicle. --Mike
1971 Targa RS - Sold 1964 BMW 1800Ti 1969 BMW 2002 |
Somatic Negative Optimist
Mike: If the arm is not too much bent, some heat and a little pressure could bring it back. Otherwise, I would prefer to stay with the right size bolt and file out the hole.
Tim Polzin: Shovel the snow in front of the garage and come to the Canyon Drive: http://members.shaw.ca/zielke/schedule.html
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Irrationally exuberant
Re: Re: alignment
![]() -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
bent
You haven't worked on many bent Porsches.
to my understanding the rear control arms are designed to be flexable.. meaning that it's not being stressed for small adjustments like Otto performs.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Otto;
I'm just trying to picture the details of what you described without doing something stupid like I usually do. Option one: Brace axis of the spring plate (through the access hole) up against an immoveable object. Then use pull the lower shock mount out until the car aligns This will basically pivot the triangle created by the banana, spring plate out around the front pivot point. Option Two: Push the lower spring plate out (by pushing against what???) to accomplish the same result. Any good ideas that people have used to brace the car without resorting to a complete alignment table?
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
when my car was aligned the front camber was just on the edge of being in spec, and they said the front shock towers over time move sag inwards. |
Is it worth it to try bending the control arm if everything else is in spec? How long would it take a shop to do this? I can just buy a *new* used arm for $100 and install it myself.
--Mike
Somewhere in the Midwest
Mike, just buy a good used one. Doing anything to straighten the arm while it's on the car is likely to twist or bend something else. Your chassis is straight...do fuch! with it.
EASY has a good rep. Last edited by MotoSook; 05-27-2004 at 07:36 AM.. |
Mine was an easy fix. Somewhere in the life of the vehicle, it took a hard hit to the left rear wheel and bowed the rear torsion tube to the front of the vehicle. The guys with the frame rack were able to pull the tube back in position. It was straight forward, although they were really surprised how much force it took to do it. They honestly thought they were going to break something on this "fragile" car. Remembering that I live in a small town in Northern Alberta, the whole thing cost $75 cash and a six-pack of beer. Tim |
