Not Quite Banned
Thomas Owen's Avatar
That must be a relief... Call Parts Heaven, they should have one.
Thomas Owen
1972 911T
1972 911S
Old 05-26-2004, 07:02 AM
Otto's Avatar
alignment
porta-power the lower shock mount until the alignment comes back. You have to go to extreme measures to repair bent Porsches.
Racing Porsche for over 30 years.
http://www.OttosVenice.com
Check out the Porsche Owners Club Track event Videos
Old 05-26-2004, 08:27 AM
Senior Member
john_colasante's Avatar
Re: alignment
Great idea. And while you're at it Porta-Power the front shocks mounts together to get some extreme negative camber. Who cares if the hood gaps close up?
John Colasante
johnc911@gmail.com
www.cupcar.net
Old 05-26-2004, 08:31 AM
Mike Bonkalski's Avatar
Its just a bent part, not a bent Porsche. The t-bar tube, frame, trailing-arm brackets are all in spec. Replace the part, fix the problem.
The rear suspension is from a Carrera and was installed by the PO. It was most likely bent when he installed it. There are no signs of crash damage on the vehicle.
--Mike
1971 Targa RS - Sold
1964 BMW 1800Ti
1969 BMW 2002
Old 05-26-2004, 08:50 AM
Somatic Negative Optimist
Gunter's Avatar
Mike: If the arm is not too much bent, some heat and a little pressure could bring it back. Otherwise, I would prefer to stay with the right size bolt and file out the hole.
Tim Polzin: Shovel the snow in front of the garage and come to the Canyon Drive: http://members.shaw.ca/zielke/schedule.html
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 05-26-2004, 09:29 AM
Irrationally exuberant
ChrisBennet's Avatar
Re: Re: alignment
Or you could just attach the front fenders with spacing washers and pull the towers together with a strut bar like the F Stock guys do.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 05-26-2004, 09:36 AM
Otto's Avatar
bent
You haven't worked on many bent Porsches.
Old 05-26-2004, 11:50 AM
to my understanding the rear control arms are designed to be flexable.. meaning that it's not being stressed for small adjustments like Otto performs.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-27-2004, 04:59 AM
jluetjen's Avatar
Otto;
I'm just trying to picture the details of what you described without doing something stupid like I usually do.
Option one: Brace axis of the spring plate (through the access hole) up against an immoveable object. Then use pull the lower shock mount out until the car aligns This will basically pivot the triangle created by the banana, spring plate out around the front pivot point.
Option Two: Push the lower spring plate out (by pushing against what???) to accomplish the same result.
Any good ideas that people have used to brace the car without resorting to a complete alignment table?
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 05-27-2004, 05:31 AM
billwagnon's Avatar
Half an hour on the frame rack cured it and dialed right in afterwards.
What does half an hour on a frame rack cost? Can it cure anything?
when my car was aligned the front camber was just on the edge of being in spec, and they said the front shock towers over time move sag inwards.
Old 05-27-2004, 06:31 AM
Is it worth it to try bending the control arm if everything else is in spec? How long would it take a shop to do this? I can just buy a *new* used arm for $100 and install it myself.
--Mike
1964 BMW 1800Ti
1969 BMW 2002
Old 05-27-2004, 06:55 AM
Somewhere in the Midwest
MotoSook's Avatar
Mike, just buy a good used one. Doing anything to straighten the arm while it's on the car is likely to twist or bend something else. Your chassis is straight...do fuch! with it.
EASY has a good rep.
Old 05-27-2004, 07:12 AM
Hi Bill:
Mine was an easy fix. Somewhere in the life of the vehicle, it took a hard hit to the left rear wheel and bowed the rear torsion tube to the front of the vehicle. The guys with the frame rack were able to pull the tube back in position. It was straight forward, although they were really surprised how much force it took to do it. They honestly thought they were going to break something on this "fragile" car. Remembering that I live in a small town in Northern Alberta, the whole thing cost $75 cash and a six-pack of beer.
Tim
Old 05-27-2004, 07:15 AM
