on-ramp's Avatar
Accelerator console on engine; how many nuts?
are there only 2 nuts that hold this down? I need to take it out and replace bushings, clean, etc.
thanks.
pic:
Old 05-30-2004, 08:17 PM
on-ramp's Avatar
anyone else do this project?
Old 05-31-2004, 09:14 AM
tholyoak's Avatar
Console is attached to engine case via 3 nuts/studs, shown below it is attached via bolts on a 3.6 swap motor.
Todd
1989 911 Targa
Old 05-31-2004, 09:24 AM
on-ramp's Avatar
on my 83sc, what size nuts hold this down?
M5, M6????
Old 06-01-2004, 09:33 AM
Irrationally exuberant
ChrisBennet's Avatar
M8 nuts.
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 06-01-2004, 09:35 AM
on-ramp's Avatar
thanks.... i dont car for re-using the same 20 year old rusted nuts....and there's nothing worse than getting a stripped nut off in a tight spot.
now i have a choice between 18-8 S/S and 316 S/S.....any differences?
and nut height 4mm or 6.5mm?
Old 06-01-2004, 09:38 AM
Any reason to use SS in this application? Do like SS because it galls easily or cause it's weaker?
I just use a washer and a nyloc nut.
-Chris
Old 06-01-2004, 09:53 AM
I seem to remember there are 3 nuts.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 06-01-2004, 10:39 AM
on-ramp's Avatar
-Chris
nyloc? do you mean nylon?
ok then, what material do you recommend?
Old 06-01-2004, 10:40 AM
A normal washer and a nut is all the factory used. I use "nylocs" - nuts with locking insert material made from nylon like you use on your valve covers. "Nyloc" was the original brand name for this style of nut. Locknuts are unnecessary in this application but the taller nut protects a bit more of the exposed threads from rusting. If you use your old valve cover nuts they are even pre-oiled.
-Chris
Old 06-01-2004, 11:08 AM
on-ramp's Avatar
ok, i need to remove this and replace some bushings. will that spacer come flying out? how difficult is it to reinstall? thanks.
Old 06-03-2004, 05:02 PM
None of the pieces of that component will fly out or be tricky. If you haven't removed the throttle linkage from the console be careful to note whether it has a wire retaining clip holding the socket on the ball. The clip would be easy to miss in a dark engine compartment. I just unscrew the linkage (long wire going to transmission) rather than trying to pop the linkage off the ball.
-Chris
Old 06-03-2004, 05:15 PM
on-ramp's Avatar
what about the spacer?
Old 06-03-2004, 05:21 PM
The spacer, if it isn't part of the console, will just slide over the stud. If you don't grab it, the spacer should just stay there unless you turn the motor upside down. My memory is a little fuzzy on the spacer. I'm thinking that it was missing from later consoles but I could just be having a "senior moment".
-Chris
Old 06-03-2004, 05:40 PM
on-ramp's Avatar
ok, it seems kinda tight back there, working behind 6 fuel lines is also a bit nerve-wrecking. however, i did manage to get at 2/3 nuts using a combination of swivel/extension with a socket wrench...
i can see it taking 1/2 hr just to undo each nut....once the nuts come off, will the console come right out, or is there some kind of Chinese puzzle i need to solve to get it out?
there are quite a few 20 year old rusted parts i need to replace around this area (plus the bell crank at the transmission). hopefully the pedal response will improve
Old 06-03-2004, 06:00 PM
