kqw kqw is offline
Reference and speed sensors
I recently replaced my CHT and noticed that the rubber insulation shielding aroung the speed and reference sensors flacked off.
Is this going to cause a problem?????
The Fox
Carrera
Old 06-01-2004, 11:24 AM
Irrationally exuberant
ChrisBennet's Avatar
Yep.
The failures I've seen of these sensors may actually be a failure of the wire. Those wires sit right over the exhaust and the insulation eventually fails. At least that's what happens here in the northeast. Maybe they would work fine in someplace totally dry. The ones I've seen fail often have heat related symptoms i.e. worked until the motor got hot.
Replacing the original sensors now is much cheaper than getting the car towed or paying for diagnostic time.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 06-01-2004, 11:44 AM
kqw kqw is offline
Thanks Chris....
Can I re-insulate those wires or must I replace the sensors? If replacement is necessary, I am not sure on the correct spacing needed to put the new sensors in.
The Fox
Carrera
Old 06-01-2004, 12:20 PM
Friend of Warren
Right off the top of my head I believe the spacing is .08mm, but I would have to double check.
Kurt V
Old 06-01-2004, 12:22 PM
Oooh, soo close Kurt! If the wind hadn't blown the decimal out of place you would have been right on. (0.8mm)
If the gods have smiled on you, the sensors will slide out of the bracket and you can put the new ones in. (Yeah right!) The adjustment is accomplished with the bracket so if the bracket isn't moved you'll be all set. Otherwise you need to stick/glue an .8mm washer to the end of the old sensor and adjust the bracket that way.
-Chris
Old 06-01-2004, 12:41 PM
kqw kqw is offline
If I am correct, the only sensor that needs to be positioned is the speed sensor as the reference sensor will automatically be positioned correctly if the spped sensor is fitted correctly. (right??????)
The Fox
Carrera
Old 06-01-2004, 12:49 PM
From memory (any we all know how bad mine is), it's the lower of the two sensor that you set the gap on. I can't remember if that is the speed or reference sensor.
-Chris
Old 06-01-2004, 12:52 PM
kqw kqw is offline
The Fox
Carrera
Old 06-01-2004, 12:58 PM
KTL KTL is online now
Schleprock
KTL's Avatar
The wire sheathing on our midwest cars suffers the same fate as Chris' NE sheathing. Cooked by the exhaust.
The sensors i've replaced have all needed to be driven out of the bracket. And get busted up pretty good doing so. Just don't damage the bracket. Good luck getting them out without damaging one or the other. Hopefully the one that gets damaged is the one with the bad wiring? But, it'd be wise to replace both since the wire sheathing is most likely bad on both of them. They are unfortunately not cheap. $120 each.
Kevin L
'86 Carrera "Larry"
Old 06-01-2004, 01:44 PM
kqw kqw is offline
Thanks Kevin...
Are both the Ref. and Speed sensor the same part number? I'm having a heck of a issue locating a parts source for these sensors...
The Fox
Carrera
Old 06-01-2004, 04:40 PM
goat's Avatar
Darren at pelican parts faxed me a copy of the specs for these a while ago. I do believe that they had the same number. don't have the paper with me. Maybe he could do the same for you if you give him a call.
Pricey little wires too.
Tim.
1988 911 Carrera. Silver.
1973 914 Metalic Blue.
2012 Cayenne S
Old 06-01-2004, 04:50 PM
kqw kqw is offline
Thanks Tim.....
The Fox
Carrera
Old 06-01-2004, 04:52 PM
jc jc is offline
I replaced mine recently so here's a tip:
Before you remove the old one, tie a string to the end of it. That way when you pull it out you can use the string to navigate the new one in place through the hole behind the engine.
Cheers
jc
'88 Carrera Coupe,
Goes to 11
Old 06-01-2004, 05:14 PM
kqw kqw is offline
Gotcha...jc
The Fox
Carrera
Old 06-01-2004, 06:27 PM
Jeff Alton's Avatar
Chris is right. It is the lower one that you set the gap on (.8mm) and then the upper one is set automatically.
Cheers, Jeff
www.turn3autosport.com
Old 06-01-2004, 08:54 PM
Lorenfb's Avatar
The gap on the sensors is not critcal, as long as they are NOT forced too close
to the flywheel. As long as the bracket has not been altered/damaged, the gap
should be O.K. If the boots are cracked or damaged, you can seal and hold the
boots together (and seal out moisture) by filling the boots with RTV silicone.
The key for the sensors is the voltage generated at cranking:
1. reference - > 80-100 millivolts A.C.
2. speed - > 1.00 volts A.C.
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 06-02-2004, 12:28 AM
rob justice's Avatar
When re-fitting the sensors into the alloy bracket - is it worthwhile smearing anti-seize onto the outside of the sensor? I had one seize and fall to bits when I tried to remove it. Or would the sensor not work correctly if coated?
Old 06-02-2004, 01:05 AM
I antisieze mine but I haven't had occasion to remove them afterwards so I don't know if it makes a difference. Antisieze does not effect operation.
On the subject of grease/antisieze and it's effect on electrical contacts; I have not found it to hurt anything. On the contrary, it keeps oxygen away from the contacts and slows down corrosion.
-Chris
Old 06-02-2004, 05:28 AM
Thats cool because the one sensor that was able to be withdrawn was one hell of a state when removed from the bracket.
Mainly because of the cold wet climate over here - if its not coated - its seized.
Old 06-02-2004, 09:14 AM
Schleprock
KTL's Avatar
How about using dielectric grease? Seems that it'd serve the same purpose as antiseize Or would the dielectric grease not last as long?
goat is right. Part #'s are the same for the senders.
Kevin L
'86 Carrera "Larry"
Old 06-02-2004, 09:31 AM
