Chuck Moreland's Avatar
Need to get torxed
Where can I get a 12 point double-torx bit to fit CV joint bolts?
Preferably in the SF bay area.
Allens fit, but it's just too easy to strip them out.
Chuck Moreland - elephantracing.com - vonnen.com
Old 06-17-2004, 09:24 PM
Eric Coffey's Avatar
Surprisingly, a lot of auto parts chain-stores carry them if you need a cheap one in a pinch. Otherwise, I'd track down a Snap-On/Mac/Cornwell tool truck. Sears does not carry them (in-store). Oh, and they are commonly called "triple square" bits.
Old 06-17-2004, 09:29 PM
Chuck,
Get out the front door, turn right, walk 3 blocks toward El Camino Real, visit your local Kraegen's store, they sell those. Or, Pepboys.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 06-17-2004, 09:37 PM
Not a torx, they are 6 pointed. Double torx, 12 point.
I think Wayne's tool is the right one. Kragen doesn't have them.
But thanks for directions to Kragen, I need some oil
Old 06-17-2004, 09:51 PM
Triple Square.
Old 06-17-2004, 10:03 PM
H.G.P.'s Avatar
Mine say "12 Point Metric Internal Wrench Set" , I bought the set at AutoZone for my flywheel R&R. The set has sizes 6, 8, 10, 12 mm. (would have chosen Pelican of course if closer location).
1969 911 E Coupe
"Little Bull" "Horse"
"H." Heart, "G." Gears, and "P" the Porsche
Old 06-17-2004, 10:04 PM
vash's Avatar
that company LISLE? sells them at all regular auto parts stores. but if i was messing with them i would want sears or better. snapon? those things are hell if stripped.
poof! gone
Old 06-17-2004, 11:30 PM
mcmaster.com
Old 06-18-2004, 05:26 AM
Lisle is a good "made in USA" product that has a lifetime warranty. They make them for most other brands.
87 Carerra Coupe
04 GMC Yukon
07 Mazda 3
00 GMC Sierra
Old 06-18-2004, 05:35 AM
304065's Avatar
Chuck, this is your lucky day.
I happen to have right here a HAZET tripple square, 8mm, both a socket and a wrench. I just bought them from www.samstagsales.com ( because Pelican does not carry HAZET). It turns out that they were the wrong size, I needed 10mm.
They can both be yours for $31, which is what I paid. I'll ship them for free because you are a great guy.
PM if interested.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 06-18-2004, 05:58 AM
KTL KTL is offline
Schleprock
KTL's Avatar
I too have the Lisle brand. Good quality hardened, black oxide bits that come in kit form. One strike against them is that they aren't built into sockets. You can easily cut them down (they're about 2-1/2 in. long) and then insert them into a socket
Kevin L
'86 Carrera "Larry"
Old 06-18-2004, 06:16 AM
Chuck,
I bought mine set of 3 at Pepboys, I saw them the other day still at Pepboys. I have also seen them at Napa, Autozone, and Sears.
A set of 3 goes for $12 or such.
Old 06-18-2004, 07:09 AM
Irrationally exuberant
ChrisBennet's Avatar
Just to pile on poor Chuck; they are called "triple squares" or "XZN" bits. I like the German ones (Stahwille, Hazet, Elora). I bought a set of cheap triple square bits once when I was in a pinch and they turned out to be made of a special metalic cheese alloy.
Triple squares from Hazet and Elora are also available in long shaft (120-140mm depending on diameter) versions which are handy for CV joint bolts and 964 head studs.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 06-18-2004, 07:45 AM
