smestas's Avatar
Send a message via AIM to smestas Send a message via Yahoo to smestas
Second drive on a rebuild - KAABOOM!
I was on my second drive after a full rebuild of my motor and about 10 minutes from home after a 1hr drive I hear a deep thud and a KAABOOM!
Within a flash all of the carnage images and post I've read here on the site went flying thru my head. I turned off the motor, pressed in the clutch and managed to limp to the side of the road. After a bit of pannic and a extigushier in my hand I finally saw what happen. The drivers axle had come loose from the tranny flanges and was just hanging there. WTF I torqued all of those allens twice and in the recomended pattern. I had to call the wife to bring my jack and tools and managed to get the c/v reconected and limp home. Funny thing was that all of the bolts were still there and in perfect shape.
Boy was that a nice scare for me!!!! I did a quick search and it seems that this is a common problem. What can I do the second time around to make sure it doesnt happen again?
The Culprit - so much for a perfectly clean motor & tranny
Dented Pipes
Torn Up outer c/v boot
Simon Mestas
'78SC Coupe
My Pelican Page | AlfaBB - Alfa Romeo Forum
Old 07-16-2004, 11:34 PM
dickster's Avatar
thats tough, at least its not terminal.
how about some thread lock?
Rich
'86 coupe
"there you are"
Old 07-16-2004, 11:55 PM
smestas's Avatar
Never would I have thought that I'd be happy to see my axle hanging down from my car!
I think loctite would be a good idea. I installed them dry the first time so I'll try anything that helps the second time around.
Simon Mestas
'78SC Coupe
Old 07-17-2004, 12:03 AM
geof33's Avatar
I'd torque them, stress them, then go back and do it once again. Between the centrifugal force, heat etc, there was probably some expansion which allowed the bolts to loosen.
This is a common problem on downhill bike rigs... So much stress that the crank bolt can't hang. Usually takes three good, stressful rides to get them to stay tight. Thread lock helps. Obviously heat is not an issue on a bike but the idea is the same.
GruppeB #935
84 Carrera Targa B.A.S.T.A.R.D. (for sale)
82 SC RSR Project (on ebay)
95 Dodge Ram 2500
03 Toyota 4runner
Old 07-17-2004, 12:05 AM
chrisreale's Avatar
happened to me on my 914 the other day. I was only one block away from home, but it scared the hell out of me as well. Those things flopping around down there can really wreck havoc, especially if you are at speed and it knocks the starter off!
1973 914 2.0 PCA Member GGRwww.pelicanparts.com/gallery/chrisreale/
www.914club.com
Old 07-17-2004, 12:36 AM
Send a message via AIM to 82SC
scary...are they new CVs? did you have enough grease in them?
I could imagine if the races locked up, it could do something like that....I have a CV shatter on me...scared the crap out of me
MJ
Old 07-17-2004, 01:26 AM
smestas's Avatar
They weren't new CV's but I did clean them and repack them with plenty of CV grease, new boots and gaskets upon instalation of the fresh motor.
My first drive was about 20min and my second drive before it abruply ended was about 1hr.
I think I'm going to go with safety wire and some serated washers this time around. Here is a interesting post on the topic I found from a search.
Safety wiring CV joints
Simon Mestas
'78SC Coupe
Old 07-17-2004, 01:50 AM
smestas's Avatar
Hmmmmmmm..........
I was just looking at this CV diagram and am now realizing that I didn't have any lockwashers or backing plates on my any of my CV hardware!!!! I just reassembled them as they were before I took them off. Once again the fixes of the PO coming back to haunt me.
Simon Mestas
'78SC Coupe
Old 07-17-2004, 02:22 AM
smestas's Avatar
Are the backing plates only for the inside CVs? Or do both the insides and outsides get them?
Simon Mestas
'78SC Coupe
Old 07-17-2004, 02:24 AM
You do not have permissi
john70t's Avatar
I think some ingeneous people on this board have drilled the heads and saftey-wired them for this reason. The red Locktight might cause more problems down the road.
Old 07-17-2004, 02:59 AM
I'd avoid loctite if you could. Those bolts have a strong tendancy to strip out the heads with no thread locker to begin with. Make sure they are new if possible and retorque after a week or two to check.
Old 07-17-2004, 03:48 AM
Did the bolts loosen or did the shaft come out of the joint?
87 Carerra Coupe
04 GMC Yukon
07 Mazda 3
00 GMC Sierra
Old 07-17-2004, 04:52 AM
Jim Smolka's Avatar
Recommend going with new fastners. The washers in the above drawing are 'ribbed' as to give an extra bite to prevent things from comming loose. Also, a bit of Blue Loctite may be in order.
To help prevent the bolts from stipping out, clean out the hex with brake cleaner and a pick and then use quailty tools such as Snap-On. My personal favorite is the Snap On Allen Sockets with a 3/8" impact. Of course this eats up allen bits, but the Snap On guy replaces them w/o any hassel. If by chance one allen hex is stripped out, an 8mm 12 point allen socket works well. Just pound it into allen bolt with a hammer, then hit it with an impact. Once again, the 12 point bit takes the abuse, but hey it is Snap On.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 07-17-2004, 05:08 AM
gregk1's Avatar
This Happend to my 930 mine came off at the stop light, The problem with mine was the gaskets, they squished out the side of the cv joint, and that is what made the bolts loosen up, they have Kind of a tin cup you put on the end of the cvjoint to contain the grease and the gasket I put them on and had no more problem I also use silicone insted of the gasket and have had no problems
65 911/ 301274 sold
66 911 /303509 sold
67 911/ 355032
68 911 softie sold
70 T with s trim
Old 07-17-2004, 05:30 AM
smestas's Avatar
The bolts loosened and came out and the whole shaft and inner CV were just hanging down.
Simon Mestas
'78SC Coupe
Old 07-17-2004, 07:54 AM
911SCfanatic's Avatar
I'd love to hear what John Walker has to say on this one.
Bill G.
'68 911 Ossi Blue coupe
Old 07-17-2004, 09:37 AM
iamchappy's Avatar
I had it happen to me last year in my 914, I used red loctite and painted red line on them so I can check to see if they loosen, so far they have stayed tight.
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 07-17-2004, 10:33 AM
Early_S_Man's Avatar
Porsche Crest
Simon,
I would recommend the hardened lock plates and Schnorr washers ... then torque to 36 lb-ft! Never had a CV bolt come loose when I use Schnorr washers!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 07-17-2004, 10:50 AM
I would buy new bolts if the allen heads are buggered up, and use blue loctite. Never had problems with mine that way.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 07-17-2004, 01:57 PM
Gon fix it with me hammer
svandamme's Avatar
inside and outsides had em on my car
mechanically , there's little difference between the insides and the outsides anyway... if your insides go loose without the washers and backing plates... so can you outsides imho
Stijn Vandamme
BIMDIESELBMW116D2019
Old 07-17-2004, 02:39 PM
