Better mixture without 02 connected
Woluld a Motronic 3.2 have a stronger part throttle map (torque wise) if it were programed to run ( ignoring the 02 sensor) with a specific value, say 13.2-13.6, vs using the 02 sensor and have to oscillate up and down to maintain
Stoich (14.7)? I realize gas mileage and emissions would not be optimal, but if torque and horsepower were, would this be the way to go? So in short I'm asking would it be better to have both part throttle and WOT maps programmed for optimum torque and horsepower? TIA, J.P. |
Diss Member
The O2 sensor is the part of the system that really fine tunes what the mixture is. How could removing it give you better mixture control?
If you want it to run with a specific map of 13.2-13.6 call Steve Wong and have him make you a chip that runs there. It won't run better then having it run where he sets them normally and it would consume more gas. Oh, and it would idle rougher. Wayne
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
John Last edited by rzepko6194; 09-06-2004 at 07:24 AM.. |
Designer King
Jpahemi,
Without the O2 info your control pressure would be almost the same regardless of engine/air temps, so your cold starts and warmups might be bad. I essentially have this kind of setup in my car as I have no DME or cat, and I could set up the car to either start very well or run very well but not both. Since where I live, cold starting can be an issue, I am running an older, vacuum controlled WUR instead of the previously DME controlled one. I don't know where you are, but perhaps cold starts are not a concern. You also would not have an enrichment for altitude changes or WOT, or you would ALWAYS have it, which may not be good for around town economy, or give you part throttle bucking or idle hunting.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone Last edited by Paulporsche; 09-06-2004 at 07:34 AM.. |
Genrtlemen, thanks for your replies. I'm a little confused (what else is new). When the throttle switch for WOT is activated, the O2 sensor input is ignored and the chip runs the corresponding map value set by the program, in this case 13.2-13.6 (SW chip). During the part throttle position, the O2 loop is activated to achieve Stoich (14.7), that part I get. Now, as in the Euro cars, can't the part throttle map be programmed to run the same 13.2-13.6 ratio? Wouldn't this give optimum performance for that map? I'm not certain how the chip knows it's giving 13.2 in the WOT map if the O2 is inactive. Is this a preset value that the programmer knows based on experience with enigine design and various other data?
TIA, J.P. |
"So in short I'm asking would it be better to have both part throttle and WOT maps programmed for optimum torque and horsepower?"
What do you think Porsche/Bosch did? Do you assume that they didn't understand engine thermodynamics and FAILED to optimize the 3.2 DME? "Now, as in the Euro cars, can't the part throttle map be programmed to run the same 13.2-13.6 ratio? Wouldn't this give optimum performance for that map? I'm not certain how the chip knows it's giving 13.2 in the WOT map if the O2 is inactive. Is this a preset value that the programmer knows based on experience with enigine design and various other data?" All B.S. & hyperbole! You've been listening to the performance chip marketing hype. 1. To precisely control the A/R ratio, a feedback element is required, i.e. O2 sensor, either a narrow band (older cars) or a wideband (newer cars). Without an O2 sensor, the DME CAN'T control the A/F to a desired/critical value! 2. The max. torque occurs at an A/R of 12.6 (see the data at www.systemsc.com on the Graphs page and read the info on the Technical page). A value of 14.7 insignificantly effects the max torque as seen on the graphs. 3. At WOT the DME ignores the O2 sensor and as such can only achieve a TARGET A/R which probably is not the optimum one for max torque. 4. Most/All aftermarket fuel injection systems, e.g. Motec, use a feedback element to optimize the A/R ratio over the complete torque curve. Bottomline: The 3.2 DME works great for what it was designed for as programmed by Porsche/Bosch. Based on the overall system design, there's little to be gained by performance chip mods. GET REAL, when it comes to believing the HYPE about them and the resulting DME performance effects. Buy a few Bosch fuel injection books & READ, and ignore the B.S. presented by many!
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone Last edited by Lorenfb; 09-06-2004 at 10:05 AM.. |
Don't the aftermarket chips already reprogram full throttle and part throttle maps? I chiped my VW Jetta and the biggest seats of the pants feeling came from part throttle response.
Irrationally exuberant
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Yes Loren, Bosch failed. They produced a program that yields good gas mileage, emissions and tolerance to poor fuel quality. I tend to believe if power was paramount in developing the program for the 3.2 , a different chip program would have evolved. They let me down!!!
Do you think the thousands of $'s I spent was wasted?? I've been had. Why me??? :~( J.P. |
Make Bruins Great Again
Before you listen to Loren (who is incredibly knowledgable in many areas) tell you what he thinks about other people's aftermarket chips, we need to know if he is prejudiced by his business dealings:
Now, as far as the O2 is concerned, disconnecting it sends an open loop signal to the DME. I have smoother idle (cold or warm) with mine disconnected (prolly needs replacing anyway).
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
I'm not trying to be argumentative as I've promised to "only use my powers for good"
but please Loren, don't cut my sentences in half to make your case (like you did the last time).Quote:
-Chris
"Yes Loren, Bosch failed. They produced a program that yields good gas mileage, emissions and tolerance to poor fuel quality. I tend to believe if power was paramount in developing the program for the 3.2 , a different chip program would have evolved. They let me down!!!" - Naivete -
A chip marketing program's best accomplishment - Reaches one who totally "sucks up the all hypepole".
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone |
![]() Funny thing, we can't seem to get a straight answer out of the man.
Designer King
Chrisbennet,
Thanks for clarifying.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
"Chrisbennet,
Thanks for clarifying." Clarifying what???????? "The 12.6 number is a textbook number I assume. Every motor is different." - Chris Bennett - The 12.6 is a theoretical value which varies little between ALL engines! DO SOME READING AND DON'T ALWAYS BELIEVE THE "HEAR-SAY". Bottomline: As I said, to control the A/F ratio, requires a feedback element, e.g. an O2 sensor which is what basically was initially asked. It's B.S. to assume that basic fuel maps can control the A/F ratios without an O2 sensor over all loads and driving conditions. THAT'S WHY AN O2 SENSOR IS USED TODAY ON ALL CARS!
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone Last edited by Lorenfb; 09-07-2004 at 01:57 AM.. |
So in order to have optimal AFR, regardless of fuel managemnet type, you need the O2 sensor as intergral part of the system. Systems like Motec allow the user to optimize for power vs. the stock DME sytem used in the 3.2 which was designed with different parameters. Ok, I understand.
Essentially, the Euro cars can only guess AFR since the O2 is absent. J.P. |
Designer King
Loren,
ChrisBennet clarified my confusion between Motronic and CIS.
