Did you get the memo?
This all brings back memories of my T.......rusty pictures make me all sentimental.
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
"I dont what part of canada your car is from but, I've seen cars from canada with only 3years on them and rust started on the fenders and quarters....."
This was a Texas car Tim K |
i'm gonna throw my two cents in although i'm no expert.
my car had "rust issues" that most of you would walk away from. the fenders were replaced and resprayed the door jambs were replaced and resprayed the little spot were the bumper meets the body still has a little spot of rust there's a little bubling on the passenger side under the plastic piece under the carpet by the battery it appears some rust was repaired but, the car ran and drove better than anything i had driven and was in the best condition(minus the rust) that i could afford. i was looking for a 10k SC and the fact that this one only had 56k miles when i got it made it worth the "rusty" history. did i make the wrong choice? I'll never know. I now own a car that i drive every day, love, and if a shopping cart dents my fender i can shrug it off and say "Oh well, the paints not original anyway". My .02 cents is that you need to look at a car as a whole. if repairing the two rusts spots you show costs you 600 bucks, it's better than having a car with a crap tranny that'll cost you 3500.
80 911 - First P-car.... Last edited by Tommy B; 10-07-2004 at 08:56 AM.. |
I would get under the car and look at everything for evidence of rust. The spots in the photo look like rust from the outside going in, possibly as they are not bubbling out. This is just an educated guess from the photo.
In any event I agree wiht the poster who said take the car as a whole, and see if it stacks up. Mechanicals, interior, all together.
1999 Carrera2 tip arena red 2000 Boxster S tip...arena red ....black 1981 911sc targa...grey mkt.import...Rosewood 1978 911SC, guards red sunroof delete .much missed 73 914 2.0 found in a bunch of cardboard boxes, and brought back from the dead. |
Now in 993 land ...
Don't walk, RUN! I would never consider an SC with even a spec of rust. There is no need to even bother, as others have said, there is plenty of completely rust free examples out there and they are not any more expensive than what you are looking at here. It is impossible that this car has only been in TX, unless it sat through every Amarillo winter, right in a salt pile. Rust this bad is an indication that the car has been beat around and not cared for at all.
George |
"It is impossible that this car has only been in TX...."
I've got the CARFAX info, and it appears that it spent its whole life there. Tim K |
Senior Member
Please do not forget that a Texas car can be from the Gulf area and could have been in the ocean/salt spray for a long time. My 911 was sold in Austin and moved to McAllen TX entire life and not a spot of rust but I checked it over very well before buying it.
Also any metal that has been repaired or welded will have the zinc coating removed, which usually allows rust to form if the surface is not prepared properly. JoeA
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Being from Canada snow and salt on the roads is a cocktail for rust especially the underside of the car and wheel well areas, which are often very expensive to fix. I know if i lived in Canada I would be taking a drive down to California and make it a mission to by a car from that area, of low humidity and rain fall. A crappy transmission will be cheap compared to fixing lots of bodywork. Being a cheaper car to buy will often work out far more expensive in the long run.
1969 911 T (SOLD), 1977 911SC (SOLD), 1999 BMW M3 (SOLD), Current Car 2005 Lotus Exige Last edited by Aussie; 10-07-2004 at 04:58 PM.. |
