Did you get the memo?
onewhippedpuppy's Avatar
This all brings back memories of my T.......rusty pictures make me all sentimental.
‘07 Mazda RX8-8
Old 10-07-2004, 04:51 AM
Tim K's Avatar
"I dont what part of canada your car is from but, I've seen cars from canada with only 3years on them and rust started on the fenders and quarters....."
This was a Texas car
Tim K
Old 10-07-2004, 06:59 AM
Send a message via AIM to Tommy B
i'm gonna throw my two cents in although i'm no expert.
my car had "rust issues" that most of you would walk away from.
the fenders were replaced and resprayed
the door jambs were replaced and resprayed
the little spot were the bumper meets the body still has a little spot of rust
there's a little bubling on the passenger side under the plastic piece
under the carpet by the battery it appears some rust was repaired
but, the car ran and drove better than anything i had driven and was in the best condition(minus the rust) that i could afford. i was looking for a 10k SC and the fact that this one only had 56k miles when i got it made it worth the "rusty" history.
did i make the wrong choice? I'll never know. I now own a car that i drive every day, love, and if a shopping cart dents my fender i can shrug it off and say "Oh well, the paints not original anyway".
My .02 cents is that you need to look at a car as a whole. if repairing the two rusts spots you show costs you 600 bucks, it's better than having a car with a crap tranny that'll cost you 3500.
80 911 - First P-car....
Old 10-07-2004, 08:54 AM
ASD ASD is online now
ASD's Avatar
I would get under the car and look at everything for evidence of rust. The spots in the photo look like rust from the outside going in, possibly as they are not bubbling out. This is just an educated guess from the photo.
In any event I agree wiht the poster who said take the car as a whole, and see if it stacks up. Mechanicals, interior, all together.
1999 Carrera2 tip arena red
2000 Boxster S tip...arena red ....black
1981 911sc targa...grey mkt.import...Rosewood
1978 911SC, guards red sunroof delete .much missed
73 914 2.0 found in a bunch of cardboard boxes, and brought back from the dead.
Old 10-07-2004, 10:49 AM
Now in 993 land ...
aigel's Avatar
Don't walk, RUN! I would never consider an SC with even a spec of rust. There is no need to even bother, as others have said, there is plenty of completely rust free examples out there and they are not any more expensive than what you are looking at here. It is impossible that this car has only been in TX, unless it sat through every Amarillo winter, right in a salt pile. Rust this bad is an indication that the car has been beat around and not cared for at all.
George
81 SC (sold)
Old 10-07-2004, 11:15 AM
Tim K's Avatar
"It is impossible that this car has only been in TX...."
I've got the CARFAX info, and it appears that it spent its whole life there.
Tim K
Old 10-07-2004, 01:15 PM
Senior Member
Please do not forget that a Texas car can be from the Gulf area and could have been in the ocean/salt spray for a long time. My 911 was sold in Austin and moved to McAllen TX entire life and not a spot of rust but I checked it over very well before buying it.
Also any metal that has been repaired or welded will have the zinc coating removed, which usually allows rust to form if the surface is not prepared properly.
JoeA
Old 10-07-2004, 04:17 PM
Aussie's Avatar
[My .02 cents is that you need to look at a car as a whole. if repairing the two rusts spots you show costs you 600 bucks, it's better than having a car with a crap tranny that'll cost you 3500.
Yes but usually after you fix the two rust spots you will often find that they were the tip of the iceburg and whole life of the car you find rust spots breaking through in other areas.
Being from Canada snow and salt on the roads is a cocktail for rust especially the underside of the car and wheel well areas, which are often very expensive to fix.
I know if i lived in Canada I would be taking a drive down to California and make it a mission to by a car from that area, of low humidity and rain fall.
A crappy transmission will be cheap compared to fixing lots of bodywork.
Being a cheaper car to buy will often work out far more expensive in the long run.
1969 911 T (SOLD), 1977 911SC (SOLD), 1999 BMW M3 (SOLD), Current Car 2005 Lotus Exige
Old 10-07-2004, 04:56 PM
