Pragmatic Dreamer
larry47us's Avatar
What about a Short Shift Kit?
Kermit has a short shift kit installed on him. I have had a bit of difficulty shifting since I picked him up. Supposedly the linkage bushings are OK, and the mechanic I have it at is looking at adjusting the linkage.
He said that he thinks that the problem may be the short shift kit.
Question: If I have him take the short shift kit off, is this just a removal of parts, or is there something else that needs to be installed to take its place? I don't know if the short shift kit is an add-on or a replacement for factory installed parts.
TIA.
larry
2004 - 911 - 996 Targa - Dark Teal Metallic, with Natural Brown Leather interior.
1973 - Viper Green 911E Targa - Kermit - gone but not forgotten
Kermit's Short Story and Pix 911E Website
Early 911S Registry Member #537
Old 11-03-2004, 03:03 PM
Bill Verburg's Avatar
It's, just parts, I'm sure someone would love to swap you.
Bill Verburg
Old 11-03-2004, 03:05 PM
Randy Webb's Avatar
I think most of these are add-ons (glue-ons) to the factory lever.
So, you will need a swap. Or you could buy one from a wrecking yard, eBay etc.
Post a pic and the experts here can ID the manf. Also search on this....
Old 11-03-2004, 03:12 PM
if its a factory short shift it is more than just parts. The lever is one of the parts.
Kevin
'79 Coupe
Old 11-03-2004, 03:13 PM
um since when is a shift lever not a part? Did I miss something?
Bill Verburg
Old 11-03-2004, 03:29 PM
Oh in case there is any doubt, this is an entire factroy short shift kit, parts is parts.
Bill Verburg
Old 11-03-2004, 03:31 PM
Randy Webb's Avatar
Maybe he means that special aura that comes with the factory Crest
you know - the one that costs 80% extra.
Old 11-03-2004, 03:35 PM
84porsche's Avatar
Send a message via Yahoo to 84porsche
That looks familiar but at least in my experience the short shift kit is a little difficult to shift with especially with the 915 tranny and in lower gears. It almost has to be babied when shifting.
Modes of Transportation:
1984 Porsche 911 Targa
2003 VW Jetta GLI
Old 11-03-2004, 03:36 PM
84porsche's Avatar
Try the shift knob - I had a friend order it for me and the damn thing was so expensive comapred to the cost of the short shift kit. He had to break the factory one off because it was glued with some strong adhesive.
2003 VW Jetta GLI
Old 11-03-2004, 03:40 PM
I could show that same picture but I don't believe it is glued on to the factory lever.
Kevin
'79 Coupe
Old 11-03-2004, 03:41 PM
hkspwrsche's Avatar
The add on/extension randy was talkin about was an aftermarket kit that used to be about $40. It was the cheapest kit you could buy. The weltermeister and factory kit short shift have a solid lever.
Harold
Old 11-03-2004, 06:15 PM
Bill showed you the factory short shift kit.
Here is the one described by Harold. It was labeled as a Target short shift kit:
... and here is the Weltmeister SS version:
Hope this helps,
Sherwood
Old 11-03-2004, 06:32 PM
I just sold a '70T with a short shift kit. I also found it difficult. I much prefer my '66 911 with stock system and new bushings. I would replace it with stock.
Old 11-03-2004, 09:06 PM
The shift housings for the 901 and 915 gearbox are different so I don't think you can make any direct comparisons with how a short shift kit works for each one.
Sherwood
Old 11-03-2004, 11:43 PM
