ZF Limited Slip testing question
Testing a 80% ZF Limited Slip
The Porsche repair books say hold the LSD body in a vice and see how much torque it takes to turn one axle stub.
914 book says 50 ft/lb.
911 book says 80 ft/lb.
Also found a note that says put one axle stub in a vice and check the torque at the other stub, LSD body "floating". Should measure more than 25 and as high as 75 ft/lb.
I measure 150 ft/lb. using the one stub method.
and
40 ft/lb. if I check stub to stub.
Comments?
Thanks,
Ken
Old 11-28-2004, 08:20 AM
pwd72s's Avatar
bump! Hope John Walker sees this...
Old 11-28-2004, 10:50 AM
Hope anybody with some experiance see this.
Ken
Anything worth doing is worth doing in excess
Every silver lining has a cloud
Assume Nothing
Old 11-29-2004, 08:03 AM
