ZF Limited Slip testing question
Testing a 80% ZF Limited Slip
The Porsche repair books say hold the LSD body in a vice and see how much torque it takes to turn one axle stub. 914 book says 50 ft/lb. 911 book says 80 ft/lb. Also found a note that says put one axle stub in a vice and check the torque at the other stub, LSD body "floating". Should measure more than 25 and as high as 75 ft/lb. I measure 150 ft/lb. using the one stub method. and 40 ft/lb. if I check stub to stub. Comments? Thanks, Ken Last edited by ken180; 11-28-2004 at 07:24 AM.. |
bump! Hope John Walker sees this...
Hope anybody with some experiance see this.
Ken
Anything worth doing is worth doing in excess Every silver lining has a cloud Assume Nothing |
Thread Tools | |
Rate This Thread | |
