source for turbo "heat blanket"
l`ve got a glass rear bumper,any heat from my new turbo system that l can contain is a good thing.Have any of you seen the turbo blankets that are fitted onto the hot side of the turbo? l know about the heat wrap,l`ll need that too but the cute little blankies,that`s what l`m really after.any help appreciated..
my life begins at 150MPH |
Here is what I am running on mine.. plenty of material to screw it up and do it over if required
http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=4782&prmenbr=361 |
Are there any down sides to wrapping the turbo?
A hotter turbo is one of them.
Since radiative heat is your biggest worry you could buy some thin sheet aluminum and place a shield somewhere between the turbo and bumper. That way the bumper is protected and the turbine housing can still shed heat too. |
I make the time to let her cool down before shutdown.. listen to song on the radio or a couple of Ramones tunes on disk.
Unregistered
Try turbo city, www.turbocity.com
they might have what you need. |
Crotchety Old Bastard
I run a fiberglass bumper also -- but do not have a heat planket on the turbo. I put one on the inside of the BUMPER. That way I know it will never be in danger from the heat. There is a large air barier between the turbo, muffler, and bumper blanket that helps as well.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
