Need wiring help for a second alt warning light.
What's the best way to wire a second alt warning light.
I currently have one wired to the stock alt warning light. It worked once upon a time but has not been operational for some time now. I've checked all of the obvious things. I suspect there's a better way to wire these things than to just piggy back on the existing leads from the stock warning light. Any suggestions?
'83 SC |
try installing a volt ga
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
How would one wire that?
'83 SC |
one of gods prototypes
i did this with led's, and the oil pressure also.
this light will always let you know if the fan belt broke. here's the thread custom cht guage install.....and lights
Brought to you by Carl's Jr. |
