Bill, do you run 12:1 on pump gas?? Or is that the good old Mahle "12:1 but if you measure it they are more like 10.8" overstated ratio?
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
How do you get the wrist pins in if they are tapered?
Me like track days
The ID is tapered - lighter
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
Craig,
I assume you're not talking about the motor you just put in your car?
Don 24 Cayman GTS - GT Silver 23 Cayman GTS - Arctic Grey - Sold 97 993 Coupe - Arctic/Black - Sold 13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue |
Me like track days
No, this is a different animal -
Why is this so asymmetrical? I would think an even balance would be most important with these things. Thanks for any info anyone can provide. C.W. |
Me like track days
Bill, do you also have the 3.8 heads/valves?
Have you run this on the dyno - FWIW, what were the #s? THX
I am curious too Bill. I have a 3.6 comming in peices that I am going to put into my car. All options are still on the table including high compression 3.8 with cams. I searched but did not find much about your motor specs.
Thanks, Jeff
Bill Howard and I did our engines at the same time, he out bid me for some mg, RS intake manifolds, see his prevoius post w/ the link to Steve Timmins site, mine is #5 and Bill's is #6 under the 3.8 section Quote:
Thanks, C.W.
Those pistons are a slipper skirt design, advantages are;
Lightens the piston, which, in turn, increases the speed range of the engine. Reduces the contact area with the cylinder wall, which reduces friction. Allows the piston to be brought down closer to the crankshaft without interference with its counterweights.
Me like track days
Also using slightly lager valves with smaller valve stems. Stay tuned.
Not my engine, btw.
All the 993 valves have ~7.9mm stems, compared to the ~8.9mm stems previously used.
base 993 was 49/42.5mm, going up tp 51.5/43.5mm. bigger are available aftermarket, a friend is using 54mm Ti in his GT. talk about expensive
Team California
Seems like an awfully high money/performance ratio, I mean 300+ HP is not slow but certainly not high HP either. What am I missing here?
Denis |
Me like track days
All degrees of tolerance for the ultimate engine, Denis......ultimately none of this 911 ownership really does make sense, does it? ;-)
Standing By...
Chris https://dergarage.com ‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8 |
Me like track days
Does that say Motec?
Whatever happened to the guy who was going to use m/c throttle bodies to make a cheap induction setup?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Me like track days
Wasn't this guy -
