Jeff Alton's Avatar
Bill, do you run 12:1 on pump gas?? Or is that the good old Mahle "12:1 but if you measure it they are more like 10.8" overstated ratio?
Jeff
www.turn3autosport.com
Old 01-24-2005, 05:54 PM
klaucke's Avatar
How do you get the wrist pins in if they are tapered?
Old 01-24-2005, 05:59 PM
Me like track days
Craig 930 RS's Avatar
The ID is tapered - lighter
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 01-24-2005, 06:03 PM
don911's Avatar
Craig,
I assume you're not talking about the motor you just put in your car?
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
Old 01-24-2005, 06:08 PM
Me like track days
No, this is a different animal -
Old 01-24-2005, 06:24 PM
Bill Verburg's Avatar
yes, 93. electronics cover a multitude of sins.
yes, thats why i posted the 2 pistons side by side, look at the normal wristpin on the 2.7 and compare to the tapered RSR pin, grams are critical on these components. Same w/ the valves 993RS are much lighter( and bigger) than 3.2 or 964 or any of the earlier valves.
Bill Verburg
Old 01-24-2005, 07:22 PM
Why is this so asymmetrical? I would think an even balance would be most important with these things.
Thanks for any info anyone can provide.
C.W.
Old 01-24-2005, 07:52 PM
Me like track days
Bill, do you also have the 3.8 heads/valves?
Have you run this on the dyno - FWIW, what were the #s?
THX
Old 01-24-2005, 07:58 PM
Jeff Alton's Avatar
I am curious too Bill. I have a 3.6 comming in peices that I am going to put into my car. All options are still on the table including high compression 3.8 with cams. I searched but did not find much about your motor specs.
Thanks,
Jeff
Old 01-24-2005, 08:13 PM
yes, sodium cooled 51.5mm and 43 mm
Bill Howard and I did our engines at the same time, he out bid me for some mg, RS intake manifolds, see his prevoius post w/ the link to Steve Timmins site, mine is #5 and Bill's is #6 under the 3.8 section
Not sure what you are looking at, but the pins are axially symmetric.
Bill Verburg
Old 01-25-2005, 04:52 AM
Originally posted by Bill Verburg
Not sure what you are looking at, but the pins are axially symmetric. [/B]
I mean the piston is different on one side of the pin from the other. There must be a reason for this, I'm just curious as to what it is.
Thanks,
C.W.
Old 01-25-2005, 05:40 PM
Those pistons are a slipper skirt design, advantages are;
Lightens the piston, which, in turn, increases the speed range of the engine. Reduces the contact area with the cylinder wall, which reduces friction. Allows the piston to be brought down closer to the crankshaft without interference with its counterweights.
Bill Verburg
Old 01-26-2005, 05:32 AM
Me like track days
Also using slightly lager valves with smaller valve stems. Stay tuned.
Not my engine, btw.
Old 01-28-2005, 12:53 PM
All the 993 valves have ~7.9mm stems, compared to the ~8.9mm stems previously used.
base 993 was 49/42.5mm, going up tp 51.5/43.5mm. bigger are available aftermarket, a friend is using 54mm Ti in his GT.
talk about expensive
Bill Verburg
Old 01-28-2005, 02:19 PM
Team California
speeder's Avatar
Seems like an awfully high money/performance ratio, I mean 300+ HP is not slow but certainly not high HP either. What am I missing here?
Denis
Old 01-28-2005, 02:47 PM
Me like track days
All degrees of tolerance for the ultimate engine, Denis......ultimately none of this 911 ownership really does make sense, does it? ;-)
Old 01-28-2005, 03:01 PM
CBRacerX's Avatar
Standing By...
Chris
https://dergarage.com
‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8
Old 01-28-2005, 03:15 PM
Me like track days
Does that say Motec?
Old 03-08-2005, 11:11 AM
randywebb's Avatar
Whatever happened to the guy who was going to use m/c throttle bodies to make a cheap induction setup?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 03-08-2005, 11:57 AM
Me like track days
Wasn't this guy -
Old 03-08-2005, 12:01 PM
