tbitz's Avatar
A narrow band (ie: normal) O2 sensor only tells you if you are richer or leaner than stoic mixture.
A wideband O2 sensor actually tells you air fuel ratio mixtures.
With a turbo, knowing that the mixture is rich may not be enough for optinal tuning. You may want to know what the air fuel ratio actually is.
Also note the O2 sensor should be place AFTER the turbo, because increased pressures in the exhaust causes errors in the O2 sensors readings.
EDIS is Electronic Distributorless Ignition System. It uses a tooth wheel that is mounted on the crank to determine when to fire the spark.
Cheers,
Tony
'78 911SC with BITZRACING EFI conversion kit
Old 04-23-2005, 05:01 PM
Irnwill,
Is that a distributerless Ign you are running? If so, Where can I get one for a 79 3.0?
Tony I will be ordering a system from you in a week or so, this thread will save me alot of time. What is required of the laptop to run your program?
Oscar, Bang up job on that airbox.
Mike
79SC driver
77S targa work in progress
Old 04-23-2005, 05:06 PM
KobaltBlau's Avatar
This is COOL! nice work Oscar, Tony, Irnwill.
Andy
Old 04-23-2005, 05:10 PM
tbitz's Avatar
Laptop needs to have a serial port, be a Pentium I or better, running Windows and a floppy drive is handy for transfering files.
Tony
Old 04-23-2005, 05:11 PM
I should be squared away. Thanks you will be hearing from me soon.
Now that I take a second look, Irnwill must be running a later engine than my old 79.
Mike
79SC driver
Old 04-23-2005, 05:30 PM
What you need for a distributorless ignition
Read and Read again
http://megasquirt.sourceforge.net/extra/edis-whatyouneed.html
This guy sells a pretty good crank trigger setup
http://www.goingsuperfast.com/FORPORSCHE.html
I also bought some items from Brian
http://home.earthlink.net/~beanbooger/boost_engineering/
These guys sometimes run items through Ebay for less $
Will R.
87 Carrera 3.3 Turbo
Old 04-23-2005, 10:17 PM
bb-how's this turbo setup working out for you? I'm thinking about doing the same to my 2.7.
Old 08-07-2005, 11:15 AM
3 restos WIP = psycho
kenikh's Avatar
BTW, if your laptop doesn't have a serial port, you can get a USB to serial adapter, no problem.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 08-07-2005, 03:23 PM
