RG5 RG5 is offline
replacing cam feed line, RHS.
I have ordered a 3.2 Carrera RH cam feed line. It this something that is relatively easy to replace? Is it just a matter of unbolting the old one and swapping over. Will the line be under pressure with the engine cold?
Any helpful hints welcome
Old 05-20-2005, 05:22 AM
AFJuvat's Avatar
You will get some oil running out of the fittings when you remove it, but no serious pressure will be inthe lines.
You will have to remove the AC compressor to make access a lot easier.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 05-20-2005, 05:25 AM
RG5 RG5 is offline
No AC on my car so it should be OK.
Any other issues to watch out for?
Old 05-20-2005, 05:30 AM
kqw kqw is offline
On the banjo fitting (next to the valve cover) you have washers. Don't loose them.
The Fox
Carrera
Old 05-20-2005, 06:46 AM
