replacing cam feed line, RHS.
I have ordered a 3.2 Carrera RH cam feed line. It this something that is relatively easy to replace? Is it just a matter of unbolting the old one and swapping over. Will the line be under pressure with the engine cold?
Any helpful hints welcome |
You will get some oil running out of the fittings when you remove it, but no serious pressure will be inthe lines.
You will have to remove the AC compressor to make access a lot easier. AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
No AC on my car so it should be OK.
Any other issues to watch out for? |
On the banjo fitting (next to the valve cover) you have washers. Don't loose them.
The Fox Carrera |
Thread Tools | |
Rate This Thread | |
