Throttle response not what it was
When I first got my 1980 SC a few months ago, the throttle response was absolutely electric. I would blip the throttle and the revs would just SCream to-wards red-line.
Recently the throttle response has slowed down quite noticeably. I cannot correlate this decrease in responsiveness to any particular thing. No recent maintenance events or improvements correlate to the decreased responsiveness. I observe two new behaviors: 1. Blipping the throttle in neutral the revs climbs more slowly with a slight roughness. 2. When the car is just beginning to warm up, the revs have a hard time stabilizing when the throttle is suddenly closed. Thanks, Matt
Matt West 1980 911 SC |
Might do a search on the frequency valve.
Joe |
Virginia Rocks!
When you got it a few months ago, it may have been cooler. You may need to lean it out a bit. Souk posted a thread on this last fall...search on that. I need to adjust my mix as well...lazy me..
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
You are getting use to the car. When I first got my 911, it was Faaast. Now I am ready to make it faster, but $$$$$$$$.
Jeff |
Designer King
Second VaSteve. See if leaning i/16 turn helps. If still not ,try another 1/16 turn. If that doesn't work, let us know.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
What about the vacuum advance? I found a similar problem with my car and removed the hose from the vacuum advance, plugged the holes, BAM whole new car.
I might not know if this is right, but if all else fails I just wanna throw this out.
Matthew “Sometimes the questions are complicated and the answers are simple.” |
Just wanted to update this post with the answer...
The fuel air mixture was off. CO was at a 6 and adjusted down to 2.5. Probable cause was cleaning the gunk from around the air sensor plate. Throttle respone is electric again ![]()
Thread Tools | |
Rate This Thread | |
