In the shop at Pelican
Jared at Pelican Parts's Avatar
Starter's just clicking.....
Ok, here's one I need some advice on...
Occasionally my car just clicks when you hit the starter... However it will sometimes click but if i hold it for a sec or two, it will start going... but it's totally intermittent...
I've replaced the ground straps and installed a remote solenoid..
Ignition switch is fine
This sound like a dying starter?
Old 05-27-2005, 10:37 AM
Super Moderator
cstreit's Avatar
Is this when the car is hot? Some starters will get "heat soak" and will not turn over untill they cool slightly...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 05-27-2005, 10:40 AM
Does it hot and cold...
More so cold, actually....
Old 05-27-2005, 10:44 AM
SilverPoly's Avatar
How's the connection on the lead green wire?
I had similar problems on my SC and I too thought it was my starter. Sure enough it turned out to be a crappy connection.
Old 05-27-2005, 10:47 AM
Perhaps I should just re-wire the whole thing?
Im sure 20+ years of undercar grime has done it's toll on the orginal wires..
I imagine that it's got a considerable amount of oxidation on the leads...
Old 05-27-2005, 10:52 AM
don911's Avatar
Try cleaning your battery posts.
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
Old 05-27-2005, 12:01 PM
chibone_914's Avatar
Clean the battery posts, check and clean the connections at the solenoid. Put a little vaseline on them afterward to keep them clean. Worst case scenario, starter going kaput....
Thank you!
John
johnechi@hotmail.com
Old 05-27-2005, 12:44 PM
911mot's Avatar
Slacken the 13mm nut holding the main starter feed wire. Wiggle the wire and then tighten nut. This should keep it at bay for another couple of months. Well it did on mine.....
1984 3.2 Carrera
Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o
Old 05-27-2005, 12:47 PM
I'd be inclined to simply replace that section of wire at that point.
Just trying to remember how resistance applies to different gauges of wire...
If i remeber correctly, when you cut a wire, you you increase the resistance by half if you splice it, right?
I want to decrease resistance to allow more current flow..
Old 05-27-2005, 12:54 PM
Slumlord
Porsche_monkey's Avatar
Could just be the solenoid.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 05-27-2005, 01:19 PM
911mot's Avatar
It corrodes at the end where it needs to make a good connection to the threaded part of the starter, where it terminates. Just take it off, clean with emery paper and refit. Disconnect battery first!
1984 3.2 Carrera
Old 05-27-2005, 01:43 PM
walt's Avatar
My car exhibited fairly close to the same thing for years. Turned the switch once - click, turned the switch a second time and it started perfectly. I just reinstalled the starter after having the solenoid replaced and it seems to be working fine now.
Walt
82SC 3.0
81SC 3.6
Old 05-27-2005, 03:51 PM
Senior Member
Superman's Avatar
I had a similar problem recently. turned out to be the "yellow wire" connection on the 14-pin connector at the engine compartment fuse box. It's the post furthest away from you when you open the deck lid. Clean all connections. This one, battery posts, battery ground strap chassis connection, tranny-to-chassis ground strap, all connections at the starter, etc. You have to do this in order to have any idea whether your starter or solenoid are okay.
Mocha 1978 911SC. "Coco"
Old 05-27-2005, 03:56 PM
Had the same problem... turned out to be the solenoid.
Joe
Old 05-27-2005, 08:26 PM
She/Her
BeauBlues's Avatar
How old is your battery? If its old and tired that could be it also. Mine did the same thing. I left the lights on and the battery died, when I jump started it, it ran fine until I wanted to start it again. All it did was click. Try jumping it to see if it will start. A new battery did it for me. Or hey, you could just push start it
Gwyneth *she/her
1995 993 Guards Red
1984 911 Targa with a G50 (RIP)
Old 05-27-2005, 10:24 PM
84porsche's Avatar
Send a message via Yahoo to 84porsche
Beau,
Be careful what you wish for. We had the jumpstart and the push start already on one of the runs. If the SOCG had some of the original guys, their would be 4 red targas on the run.
Modes of Transportation:
1984 Porsche 911 Targa
2003 VW Jetta GLI
Old 05-27-2005, 10:57 PM
