Me like track days
Not a problem, but do please reread your post
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
I didn't mean RUF wheels where bling, I meant bling wheels are usually heavy large wheels better left for the esclade crowd, sorry if that affends any esclade owners, but the rappers have made them seem like a silly ride to me. But I do think heavy wheels affect suspension, breaks and acceleration.
Learn to wish that everything should come to pass exactly as it does. |
RUF wheels
Here are front and rear in boxes.
To all of you crying about wheel weight and so on, heard it okay. I simply got them because I like them. I dont care if the normal guy on the street doesnt know they are from RUF. I didnt get them for him but only for me, myself and I!
KH 964 C2 -90 9-3 1.8t -06 sold 911 3.2 -74 |
Lurkasaurus
These wheels were spec'd for a car(the CTR Yellowbird) that does about 215mph and at those speeds, I think a bit of unsprung weight is the least of your concerns - you want strength. Sure, most people will never need wheels that strong(I don't know how strong they are but I'm guessing Ruf wanted a VERY strong wheel) - but some will.
I love the way they look. No better "resto mod" wheel out there imo.
Tony '77 930 "Objects in mirror are losing" "Oh cock..." - James May Last edited by turbocarrera; 08-29-2005 at 12:08 AM.. |
Ruf rims sprayed in Porsche black(A1)
Rears:285/40/17-10inch Fronts:235/40/17-9inch Pity I cant go more than 285 with the rear 10inch rims. However I've had them on my car for 5 years, been thru potholes etc etc etc and they are still rock solid till today. I swear by them at least.
Speed Yellow 911 Ruf BTR Conversion PCS Membership No: 266 Rennlist Membership No: 050315-5911 Ebony Black 2004 Jaguar XJ6 Titanium Grey 2003 Ford Focus |
Sorry forgot to attach. Here you go.
Me like track days
They do appear to be tough SOBs. We need this on the oddball roads in the PCNW
Me like track days
Wayne said the wheels are in
Wayne Corley RUF Auto Centre 214/269-1571
The new wheels are made by Avus instead of Speedline and are actually quite a bit lighter (22lbs instead of 28lbs). That's getting a lot closer to a fikse with the awesome ruf look...
so 22 lbs? doesn't sound quite so bad. then again, what do i know.. hehehe..
how does that compare to the factory fuchs?
Paul Vandermeer '87 930 (gone but not forgotten) '01 BMW M Coupe |
Not nearly as good as fuchs, but you do have a full inch more diameter. Also, you can't get a tire wider than a 245 in 16s, which is pretty much worthless with 500plus HP...
I think fuchs are about 16lbs, really light 17s are about 18lbs, good 17s are 22 to 24lbs and heavy is 26 plus. Add 2 to 5 more pounds for 18s. More metal = more weight. -dc |
Me like track days
If anyone gives a rip, the RUF wheels have proven to be strong mothers - a nice touch, eh? ;-)
Sherwood put together a lot of wheel weight data here
FWIW the Ruf Speed lines did get a bad rep on track a few years ago, don't really know how deserved it was, I have also seen cracked Fikse and Kinesis and Fuchs wheels. I have Speedlines on my 993 for street(they are also at the heavy end of the scale) Please don't ever use the cast after markets on track though.
Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | Last edited by Bill Verburg; 09-02-2005 at 04:08 PM.. |
Me like track days
Eh, put em on and have fun.......... ;-)
I was at a wheel shop a couple of weeks ago and saw a failed (what appeared to be a) Ruf front wheel. The outer flange had broken where it meets the spokes and it appeared the metal there was barely over 1/16th" thick.
Either theres's somebody making very authentic-looking knock-offs that are dangerously poorly engineered or someone machined the wheel after it was sold. It broke on the tire mounting machine; thankfully not on the street. Be careful out there!
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
