In theory yes, but it's got to have something to do with the possibility that propane is a component of the mixture. I'll try to get the MSDS sheets and post them. If ES-12 was indeed safe, the EPA would be promoting the heck out of it. Commercial, residential and automotive applications would be changing everywhere with similar refrigerants available, due to the non-ozone depleting factors as well as no recovery or recycling of refrigerants.
Chris '80 SC |
Large Registered Member
Can I ask a really DUMB question Chris?
Uhmmm... Is this stuff legal to put in our cars? Or more importantly, is it legal to sell and purchase for the use of in a car? Or is this hopefully one that is currently slipping by regulation....
'85 Carrera Coupe, Marble Grey #118 JP/R6 '93 Lexus SC400, '00 Ford F-150 '70 911T- 2.7 (SOLD) |
I guess the above link dispells any questions of leagaity!!! Buy it while you can, but use it at your own risk.........
Damn... forgot to spell check! LEGALITY?
Thanks for the articles Jim. This thread has really gone a long way in a short time.
Can I ask a really dumb question now...what are the temperature readings at the vents for those of you that have done the R134a retrofit?
Chris '80 SC |
Warren Hall Student
I knew I really didn't want A/C in the 911 anyway.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
After a fresh charge, I will usually see a 30 degree difference at the floor vent vs. outside air temp when car is moving on the freeway.... OK, I guess, as long as it doesn't get above 95 outside.... I used to see about a 40 degree difference with the wonderful R-12... If I can score some of this new stuff, and it really works in my system, I might just just buy a couple of cases of it, and store it next to the rest of my militia gear...
Wider is Better
This link takes you to a MSDS for Envirosafe refigerant. The composition, as listed on the MSDS is 0-60% C3H8 (propane) and 0-60% C5H10 (probably cyclopentane). Both are flammable, and propane appears to be a major component. Cyclopentane is slightly less flammable than propane, and linear pentane derivatives that fit that formula will be just as bad as propane.
http://befreetech.com/esmsds.htm The MSDS for cyclopentane is below. http://ptcl.chem.ox.ac.uk/MSDS/CY/cyclopentane.html Per the MSDS, cyclopentane is "Highly flammable. Note low flash point and wide explosion limits. Incompatible with strong oxidizing agents. Floats on water so water is of limited value in putting out fires involving this material." If you choose to use it your car, just be aware of, and take responsibility for, the risks. After all, it IS still a free country.
Wider is Better |
remember 134a is 1,1,1 tetrafluoroethane
I'm not sure this makes me feel any better either.
Chris '80 SC |
Wider is Better
Another very good refrigerant is ammonia. Of course, if you could get past the severe toxicity, you sure would know if you had a leak in your system.
Wider is Better |
Another quote;
"The autoignition temp of 134a is 368F !!! Not only is that do-able under the hood, but if you breathe it at only 4000 parts per million, you die".
Chris '80 SC |
perhaps the flame aided in causing a chain reaction (autoigition) by the new higher temperature inside the Professor's chamber of horrors?
"but if you breathe it at only 4000 parts per million, you die".
Sigh! The below is from: http://www.trane.com/commercial/issues/environmental/cfc6.asp#toc R-134a toxicology.[10] R-134a also has very low acute inhalation toxicity. The lowest concentration that causes mortality in rats, the 4-hour Approximate Lethal Concentration (ALC), exceeds 500,000 ppm. The cardiac sensitization response level for R-134a is approximately 75,000 ppm. Anesthetic-like effects are observed at concentrations greater than 200,000 ppm, or 20%. Long-term exposures with very high concentrations (50,000 ppm) caused an increased incidence of benign tumors in the testis of rats. Again, none of the observed tumors were life threatening, and all occurred near the end of the study. The evidence from all tests in cultured cells or organisms, as well as in laboratory animals, indicates that R-134a is not genotoxic and that the increased incidence in benign tumors is not due to an effect on genetic material. The test findings indicate that R-134a has very low acute and subchronic inhalation toxicity, is not a developmental toxicant, and is not genotoxic.[10] Most refrigerant manufacturers recommend that TWA occupational exposures not exceed 1,000 ppm; this also is the level recommended by the American Industrial Hygiene Association, Workplace Environmental Exposure Limit (WEEL) Committee.[11] Again, exposures still should be kept to the practicable minimum. (A WEEL guide has not been published for R- 123 at this time.) It is important to note that the tumors attributable to the R- 123 and R-134a exposures were not cancerous. The findings reflect an increase in tumor incidence compared to rats in the experimental control group, those not exposed to the refrigerants. Some tumors also were observed in this control group, but not as many. Also, the recommended occupational exposure limit for each refrigerant is below the level at which toxic effects were observed in laboratory animals. The use of rats, dogs and other animals is based on accepted scientific procedures and sensitivities to specific concerns by species. The lower exposure limit affords both a margin of safety and a conservative reflection of potential differences, between responses in individual humans and between humans and test animals. Other refrigerants. Information on the toxicity of other refrigerants is available from chemical manufacturers, published literature ,and chemical and safety databases. The toxicology findings for other refrigerants covered by PAFT are also available.[10] R-123 and R-134a were summarized here as the newest of the widely used refrigerants for chillers. Other chiller refrigerants are addressed in less detail below, and a survey of toxicity data is underway, by the author, on alternative refrigerants for additional applications.[12] |
Senior Member
At home I can lounge by the pool with a margarita in hand legally. Same cannot be said about the car! ![]() JoeA
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
If you new that your system was leaking, It would be important to know if it was leaking "into" the system, and mixing with air entering the cabin... If it was leaking out of the closed system, obviously it would likely dissapate before causing any human harm? How much refrigerant actually ever bleeds into the closed system exposing possible harm to those in the car?
Yikes... Where is this thread going??
Without drawing my comments out for too long, let me say I have researched this topic before.
I found a link that was especially helpful for me. Of course, it is on the net, so take it for what its worth, but it certainly seems to clearly explain most common questions, facts, and myths about refrigerants, retro-fits, risks, and what should be done when switching between the various refrigerants. I read the articles from the beginning down to the following line and was satisfied. (about 2 pages) "Discussion and alternative automotive refrigerants" Hope this helps somebody -Matt
-Matt 1985 Targa |
-Matt 1985 Targa |
Yeah Joe, but what's the temperature of your pool?
Chris '80 SC |
Wider is Better
The HFA molecule is also about twice as large as an R-12 molecule, but the hoses in older cars will allow 134a to diffuse through the hose material, neccesitating the use of barrier hoses for conversions on older cars.
Wider is Better |
