Re: Info for R12 users
AC is nice when it's muggy / rainy out. (Targa roof on) .... or just blowing on your feet with roof off! Kato |
Diss Member
Now if you spray it on yourself you will get corrosion burns on the frostbitten areas. I have never met anyone who isn't acclimated to ammonia that could stay in a room with over 5 ppm and their eyes would be running at that level. I still think it would be way too much work to put it into a car unless you could hook it into a car alarm that would discharge a small quantity of ammonia. The attempt to steal the car would quickly stop! Hell, they wouldn't be able to get close to the car. ![]()
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Large Registered Member
'85 Carrera Coupe, Marble Grey #118 JP/R6 '93 Lexus SC400, '00 Ford F-150 '70 911T- 2.7 (SOLD) |
I am still searching the site you reference in this statement. Where can I purchase some Enviro-Safe? Thanks, Paul
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
![]() http://autorefrigerants.com/
Thanks Patrick!
Joe from the Jag group? what happen to Joe from the PORSCHEGroup? |
Senior Member
Hey, I am also "Joe from the Aeronca group," "Joe from the BMW group" as well as "Joe from the Austin Healey group" so am well spread around. Terry, the guy I mentioned is a Jag owner and he would not know me as a 911 owner. Chris, the pool was about 87 degrees today. Lounged there while sipping a Miller and catching some rays. Totally forgot about cars, bikes etc for at least 30 minutes! Joe A
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Nine9six., I'm glad Pat replied, I've been out doing what Joe described, even though my pool is 91 after running the aerator for the last few days. Here's to life!!
Chris '80 SC |
xxxx
"Todd" 98 Tahoe ,2007 Saturn Vue 86 930 black and stock, 80 930 blue tracdog 91 Spec Miata (yeah I race a chick car) "life"ll kill ya" Warren Zevon |
Just a bump to see if anyone has purchased the Enviro-Safe refrigerant and has some results that they wish to share?
Daryl G. 1981 911 SC - sold 06/29/12 |
received my order of ES-12a industrial strength the other day. I'm still pondering the purchase of a procooler R/D. I'm probably going to bite the bullet and buy one, then do the change over... As soon as I do, I will post my results!
I just received a case of the industrial grade ES12a. I'll be taking it to a friends AC shop on Friday for installation. We'll evacuate all the R12 and fill the entire system with the new stuff. Being a little slow, can anyone answer this question? My 77 911S AC system has a capacity of 47.6oz of R12, right? If this is correct, woyuld I then charge the system with 16 oz og the ES-12a? If what I'm reading, the equivalency ratio is 3 R12 = 1 ES-12a.
Any thoughts will be appreciated. I'll post results of the installation soon. Thanks! Jay 1977 911S 37,000 original miles
I know you believe you understand what you think I said, but I am not sure you realize that what you heard is not what I meant! |
www.autorefrigerants.com Please post your results!! Good luck! Pat
Update for my A/C...
I changed out the factory r/d to a ProCooler unit. Also switched to the Industrial Grade of ES12-a. The R/D change out was nothing short of a complete PITA!!!!!!! But boy were the results worth it!! I'm seeing 35 degree temps at the center vent with outside temp at 84 degrees today. That would be driving in the city at 35 mph. More interesting than that, when idling at a stop light for 2 minutes, the vent temp didn't raise even 1 degree! Before, I would typically see an immediate 10 degree temp increase within the first minute... Before the change, I would typically see only 55 degrees at the vent. Unfortunately, I didn't try the ES12a in the system prior to changing out the R/D...... This r/d unit looks to be almost 4 times the size of the OEM unit... I guess the real test will be when I see 100 degree outside temps, which are forecasted here for the next several days...
Patrick,
I changed to the ES12a industrial grade last Thursday. I live in Charleston, SC and the day I went to my friends shop to do the switch, the temperature outside was 93 and the R12 in the system was giving me an outlet temperature of about 60. After the switch, outside temp was 95 and outlet temp was 41! Great stuff! Both temps at the center outlet were taken while cruising at about 50mph. Jay 1977 911S 37,000 original mile
Awesome Jay!
Let's see how long it holds up.... I'm curious to see how the system will hold the charge, as I still have the original barrier hoses... But at $6 a can... Who friggin' cares!!!!!! What has surprised me also, is how the vent temp won't fluctuate at idle in traffic, as we all know was a huge bummer with the old system... Is that a function of the ProCooler? Not sure... I'm curious to know how your system performs at idle, and in stop & go traffic... As I just did my change yesterday, I'll keep you posted as to how mine performs as well!!
Patrick,
I haven't done much stop and go with it but I'll watch and let you know. When I bought the stuff, I hadn't paid much attention to the amount needed so I bought 24 cans! I'm 60 years old now and just hope I have enough to use it all up. Jay
