Porsche-pa
75Carrera's Avatar
3.2 speed sensor question
I'm looking for a speed sensor for my 86 3.2 motor. I'm unsure exactly what it does and haven't found any parts in the Preformance catalog named "speed sensor." Are they called something else?
Current Garage:'04 996TT S Cabriolet, 1975 911 Carrera 3.2 powered (my Precious),
Also rans...
'02 996TT, '03 996TT, 1967 912, 95 993 C2 Cabriolet, 76 911S Carrera, 2014 Carrera S, 2014 Turbo S, 1999 AMG SL, 1966 Lotus 7,
Donny
Old 08-01-2005, 02:34 PM
MBruns for President
JeremyD's Avatar
Impulse sensor?
Pelican Parts as follows
Old 08-01-2005, 03:04 PM
Porsche-pa
75Carrera's Avatar
Thanks Jeremy,
Is this timing mark sender the same as or commonly called a speed sensor?
Also rans...
Donny
Old 08-01-2005, 04:24 PM
J Smith's Avatar
No such luck. You need the expensive one ($128.55). That's the speed sensor.
Josh
'87 911 Carrera 3.2 Coupe
Old 08-01-2005, 04:48 PM
Early_S_Man's Avatar
Porsche Crest
Do you have a Bentley manual???
Speed and reference sensors are identical, so one spare can be used for either application.
What makes you think you need one? I know many on this board recommend replacement based on symptoms alone, but if you haven't looked at [tested] the signal with an oscilloscope while cranking ... you can't be really sure! There is a clearance adjustment that is quite critical ... and should be done or verified before declaring the sensor bad.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 08-01-2005, 05:10 PM
Porsche-pa
75Carrera's Avatar
Thanks Warren,
I bought this '86 3.2 motor as a complete upgrade package. It was missing a few small parts. The "speed sensor" wasn't included.
Also rans...
Donny
Old 08-01-2005, 05:15 PM
Irrationally exuberant
ChrisBennet's Avatar
There are 3 sensors that might be confused. The two you need are the "speed" and "reference" sensors. That are held in the same bracket at around 1 o'clock as you look at the flywheel. There is a 3rd sensor at 12 o'clock which you don't and never will need. It's only purpose is to plug a gap in the engine tin though you could conceivably use it for diagnostic purposes.
If the insulation on the speed or reference sensor is cracked (twist the wire a little and look closely) replace both sensors. They can scope out fine today and leave you stranded in tomorrow's rain or bucking on your next hot track day. They lead a tough life right over the hot exhaust and the original sensors are read to retire IMO.
Save the old sensor Find a 0.8mm thick washer (easier said than done) and glue it to the end of the old sensor to make a tool for setting the sensor gap. The tool is only necessary if you need to set the gap with the engine in the car.
Speaking of sensors, if the head temp sensor (on #3 head) is the old single wire kind, replace that now. Check the (white) plug for the head temp sensor, if it's got only one pin, it's the old single wire style.
BTW: Performance Products is a (higher priced) competitor to the Pelican Parts - the sponsor of this BBS so it's kinda uncool to talk about them in any way that would be detrimental to our host.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 08-02-2005, 10:44 AM
JeremyD's Avatar
Good recomendation on using the old sensor Chris!
Thanks - I would have tossed mine
Old 08-02-2005, 11:05 AM
JeremyD's Avatar
and just for the record - this is where the ref sensor sits...
Old 08-02-2005, 11:13 AM
just me
paulgtr's Avatar
Send a message via Yahoo to paulgtr
is there a procedure for changing the sensors without dropping the engine?
I've been searching and getting a ton of links for 944's but nothing about 911
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses.
http://www.hairydoggrrrage.com/
Old 09-05-2008, 08:07 AM
abit off center
cgarr's Avatar
I have done it, the hardest part was getting the wire and grommet back in. Just get a lot of room under the car
______________________
Craig
G2Performance
Old 09-05-2008, 08:11 AM
just me
paulgtr's Avatar
is that both sensors in that one spot?
Old 09-05-2008, 08:12 AM
abit off center
cgarr's Avatar
Yes, and you need to keep the proper gap setting so you don't want to remove the bracket, just the sensor.
Craig
G2Performance
Old 09-05-2008, 08:14 AM
just me
paulgtr's Avatar
cool. I am just looking it over in the bentley manual now.
I want to be careful removing the sensors, use something to loosen up the bolts before I try to get them out.
Old 09-05-2008, 08:18 AM
burgermeister's Avatar
schnellman posted a BMW part number early this year (or late last) that is the identical sensor (3" more wire) for $99 from our host. I installed one, works dandy.
I believe this is the part number:
12-14-1-708-618-M14
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 09-05-2008, 05:13 PM
buttjoint's Avatar
I also replaced mine with the bmw replacements. They are identical and arn't that hard to replace while the engine is in the car.
Old 09-05-2008, 06:46 PM
By chance do you have the BMW part #?
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 09-05-2008, 08:29 PM
KTL KTL is online now
Schleprock
KTL's Avatar
Here's more discussiion on the BMW reference sensor in case anybody's skeptical.
BMW Motronic Reference Sensor Same as Porsche Part
You have no reason to be skeptical. Think about it BMW, Porsche, it doesn't really matter because they're both using BOSCH Motronic engine management systems of the same vintage & design. So that's why there's interchangeability with the sensors.
Kevin L
'86 Carrera "Larry"
Old 09-05-2008, 09:07 PM
