Guest
Posts: n/a
Guest
Posts: n/a
twice the time and effort.
Irrationally exuberant
I think you guy meant to say "chase the stud hole with a tap".
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
MBruns for President
you are right Chris - Blond moment
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Half way through my rebuild I have now seen the light and decided to take peoples advice and change the original delivers, I just wish I had listened earlier when the case was seperated, anyway I stumbled upon this thread about stud removal which gives me most of the info I hope I will need to get these buggers out what I want to know is now I have my case re sealed will heating the head studs/case damage my through bolt hole seals?
Steve |
I think I got lucky, got all 12 studs out within an hour with no heat, is this normall or were the germans been tight on locktite when my engine was built? Im glad I didnt have any broken ones though I bet they are a B***h.
Did the case have inserts in it from a previous rebuild perhaps? (I'm assuming you have a 1972 motor, otherwise disregard this if your motor is not a 2.7 or earlier motor.) -Chris
No Chris my engine is now 3.2 just having a overhaul ready for transplant into my 72, the 2.4 found itself a new home in a VW camper van.
-Chris
Thought I would bump this old thread. It has lots of good advice in it.
Well tonight I finally tore my 3.2 down for a 3.4 conversion. (progress reports will be in the engine building forum) To make a long story short, my bragging about how lucky I have been removing studs finally bit me in the A$$! I had the first 17 out in my usual time, the bottom 12 not needing any heat at all! Then I found 7 stuborn top steel ones. Used my MAPP torch and got 6 out without much trouble and then the 7th (and last) one broke off just above the case! (insert some seriously bad language here ) Crap! Now I am not sure WTF to do! Send it out to the shop or make a last attempt to get it out, or drill it out with the drill press!I am too tired to even go back to the garage to look how much is really sticking out, but I will look at it tomorrow..... Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
![]() When you have the machinist clean up ("deck") the spigot sealing surface have him remove the broken head stud. He's got it bolted down in the mill already anyway. -Chris
When I did mine I used a cam like stud remover from sears. Took maybe an hour to get all but one out. That one broke. Picked up the case and threw it in the front seat of my jeep and drove to local machine shop where they removed it and put in a case saver. Boy that was lot of fun!!!! Machine shop thought I was nuts with the case in hand opening front door.
I removed all 12 lower head studs on my SC engine using an oxy acetylene torch and vise grips. It took around 3-4 minutes of heating to melt the loctite. Once the studs start turing, remove the heat don't stop turning. They all came out easily without thread damage. Apply heat in the area shown.
John Adams 1980 ROW 911SC |
Stahlwerks.com
This is what you get to do when they break off 1/8" from the case. Think I had to do 5 like this.....
John Helgesen Stahlwerks.com restoration and cage design "Honest men know that revenge does not taste sweet" |
Limbo
Just did a neat trick on Friday to remove 5 stubborn studs and one broken one. Weld a nut on the studs, heat the case near the stud a little bit with a propane torch and they come right out with an air wrench.
Easy, only took 20 minutes.
Big ol built Duramax Durango R/T 19’ Current Custom project V8 M3 08’ Built and spoiled |
Get a MIG welder, weld nut to stud, yes you can weld devilar, then attack while hot with large breaker bar/socket. only takes 5 min per stud and your not heating the case per Wayne's suggestion.
We're only here for a short time, so lets have a good time! J. Buffet |
Why would you try to get the steel upper ones out?... they were good, weren't they?
Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
I took them out because I am using ARP ones. I welded a nut on this morning, very little material to showing to actually weld to, and promptly broke it off! I am going to let someone who does this for a living fix it for me (my machinist
)I heated in all of the right places when I did this using my MAPP torch. NOT the first studs I have removed........ But, the first one that I have broken! Cheers
welding a nut to dilivar usually doesn't work. occasionally at best. your best shot is to use big straight jaw visegrips on the stub after clearing away all the other studs, top and bottom, so you can turn the visegrips in a circle as much as possible without having to reclamp them any more than necessary, which can chew up the stub. heat with oxy/acet as usual.
