bfrenz's Avatar
Too many grounds off one point
I'm in the process off hooking up my 3.2 DME in my 914. Where my wires run, in regards to the grounds, is the same spot where I hook up my 914 grounds.
Can you have to many grounding wires pulling from one spot. Or should it be spread out.
1973 914-6 3.2 Motronic
Old 09-28-2005, 08:47 AM
Friend of Warren
As long as all the connections are clean it doesn't matter.
Kurt V
Old 09-28-2005, 09:02 AM
I use a line of thought that says it's not the actual number of wires but the number of connectors on one lug that is the envelope. My thinking could be all wet 'cause I think marine? I max at 4 terminals.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-28-2005, 11:06 AM
Ayo Irpin, Ukraine!
70SATMan's Avatar
Theoretically it's better to have all grounds originate from one spot. It eliminates ground loops and varying potential in circuits due to ground currents. It's just not practical from a mechanical standpoint. The more lugs you introduce in any one connection to chassis, the more chances you have for degraded electrical connection.
Harmlessly passing gas in the grassland away;
Only dimly aware of a certain smell in the air
Old 09-28-2005, 11:28 AM
coloradoporsche's Avatar
Ground is ground.
Sheena is a punk rocker
Suzy Is A Headbanger
Heidi Is A Headcase
Judy Is A Punk
The Ramones' earliest titles included 'I Don't Wanna Walk Around with You,' 'I Don't Wanna Go Down to the Basement,' and 'I Don't Wanna Get Involved with You.' Dee Dee later said, "We didn't write a positive song until 'Now I Wanna Sniff Some Glue'."
Old 09-28-2005, 11:40 AM
I'm with Michael on this one.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-28-2005, 12:09 PM
randywebb's Avatar
Au contraire, what you think is ground isn't always at the exact same potential - Michael has it right. Whether gnd loops can be an issue for whatever electronics are in your model car, I dunno.
Just stack them up until you feel like it is not good mechanically then find or make another ground star.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 09-28-2005, 12:50 PM
