WydRyd's Avatar
Question Compression testers?
In the process of troubleshooting my low idle/stalling condition, I decided to do a compression test on the engine to verify the internals are OK.
Is there a special, solid extension I need for these engines? The hose on the tester I bought is slightly bent, so I'm having difficulty actually getting it in at the right angle to screw into the plug hole
Very frustrating indeed
How do u guys do it? Is there a special "PORSCHE" tool
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 12-02-2005, 06:52 PM
al lkosmal's Avatar
I bought a compression tester from Sears, for $25 or so, that has a 12" long flexible hose. Works great.
RGruppe #669
http://www.x-faktory.com/
Old 12-02-2005, 07:09 PM
Jeff Alton's Avatar
The flexible hose just takes a little patience, but it is the right thing to use..
Cheers
www.turn3autosport.com
Old 12-02-2005, 07:13 PM
This is what I did to my comp gauge hose to help fit into the sparkplug hole.
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 12-02-2005, 07:27 PM
WydRyd's Avatar
Finally got the hose into # 6 cylinder after much friggin around. I just hope it's not going to be so bad for the rest of them. I like what you've done above Doug. Very ingenious
Questions:
- Do I NEED to disable my fuel pumps?
- Must compression tests be done on a warm engine?
- How do I do a leakdown test? What type of tool/instrument is required for that?
Excuse the first-time newbie questions
Merv
'89 911 Turbo Cab
Old 12-02-2005, 10:42 PM
