-   -   The IF2 thread (http://forums.pelicanparts.com/porsche-911-technical-forum/254697-if2-thread.html)
beepbeep 03-04-2006 08:53 AM
Originally posted by DW SD
What front struts are you using? Looks like a gusstted Bilstein lower with a coil over fixture attached? OR Is it the early RSR style?
Are you changing the lower A-arms, too? OR going with a 935 style?
GREAT JOB and GREAT update!
Originally posted by captainrb
Just my .02 .. first off super,great job !!! Although I'm wondering why it is when you made a custom upper shock mount it didn't have any adjustability for changing camber
Adjustability is not yet resolved but I would like to have fix upper shock mount and adjust Camber by adjustable-length RSR-style V-arms (instead of original A-arms).
Original A-arms have been cut-and-pasted so many times that I see them as somewhat unsafe. Lobbying for RSR-arms.
beepbeep 04-04-2006 11:50 AM
Ello!
Sorry for not updating for a while. I was sick and everybody had too much to do. Progress was somewhat slow and it's boring to look at pictures that differ just slightly from previous ones.
A few new pics:
This is the structure that is going to shield engine from behind:
http://www.itsfun.nu/if3/if3_028.jpg
Spacers for rear wheels (let's just hope those bearings will survive, this wasn't my idea)
http://www.itsfun.nu/if3/if3_001.jpg
Coupe was sand-blasted, cage painted and underside of body covered with thick black sealing paint. Rear suspension was final-installed by yours truly with help of Niklas.
http://www.itsfun.nu/if3/if3_032.jpg
This is how engine fits:
http://www.itsfun.nu/if3/if3_034.jpg
beepbeep 04-04-2006 11:52 AM
Front suspension and transmission/turbocharger loop aux coolers visible:
http://www.itsfun.nu/if3/if3_035.jpg
http://www.itsfun.nu/if3/if3_036.jpg
Batterry is installed in front of passenger legs:
http://www.itsfun.nu/if3/if3_037.jpg
Capriciossa 5W45
http://www.itsfun.nu/if3/if3_041.jpg
beepbeep 04-04-2006 11:57 AM
Other things that happened:
OEM position of driver seat is sub-optimal, so piece of transmission tunnel and bottom plate under the seat was cut out in order to move seat an inch or so to the middle. This way we acheved fully optimal position of driver, directly in centre of steering wheel. Rear wing/body was also made from fibreglass.
Old pic:
http://www.itsfun.nu/if2_2006/0503/if2_019.jpg
There have been lot's of problems with fabricating throttle actuating mechanism that would keep dual throttles synchronized.
No pictures of those things yet.
DW SD 04-04-2006 12:04 PM
Looking good! AWESOME! Those rear spacers are BIG, no doubt.
Are you building a bulk-head at the front strut towers? Is that what is taped in there to the front strut brace?
Dumb question, but what black paint did you use?
Doug
beepbeep 04-04-2006 12:17 PM
Yupp. Actually, it's pieces of carbon-fibre that are taped to already welded sheet-metal (just for bling-bling). It was necesarry in order to divide trunk to front (fuel-cell etc) and rear (oil-tank, steering, brake reservoirs etc) buk head. Should fuel tank rupture, it's good to have that area divided from rest of trunk and coupé.
Doug
Dunno, gotta ask Tokan who is in charge of everything body-related. It's plain-Jane black body paint:
http://forums.pelicanparts.com/uploa...1144178251.jpg
Kroggers 04-04-2006 12:23 PM
Originally posted by livi
I am a Swede !! :D
Do Norwegians who live in Sweden count??
ChrisBennet 04-04-2006 12:40 PM
All I can say is "Wow!" Goran.
Silly question:
If one was running 3pc wheels like you have in the picture, could you unbolt the rim halves, flip the center section and bolt the wheel back together to reduce the size/weight of the wheel spacer? In other words, use the existing wheel components to create a "deep dish" wheel?
-Chris
Facey 04-04-2006 02:24 PM
Love the build
think it is neat to see what some wild imagination work can do!!!
check your pm's (user cp)
i love all the custom faberication going on!
cheers
Nick
beepbeep 04-04-2006 02:58 PM
Silly question:
-Chris
Well I guess it's possible but Jocke's 3-piece wheels have positive ET so in best case it would make things worse, moving wheels even further from hub.
With other words, we would loose the spacer (good), make rear even wider (bad) and load bearings even more (bad).
As long as imaginary center of wheel goes trough middle of the bearing, it doesn't matter how thick spacer you got.
We had some design considerations to attend among other things so wheels got spaced out. My vote was to keep the car narrow-hipped (as much as widened 930 can be) in order to keep aerodynamic drag and bearing load to minimum but I got voted down. It's a show-car, you know. Kids must say oooh and aaah and stuff. I'm not much for show but I'm not running it either ;)
In hindsight, widening wasn't such a bad idea after all as it makes place for new plenums, air-intakes for turbos, brake-cooling scoops etc.
beepbeep 04-04-2006 03:06 PM
I almost forgot.
A handmade hydraulic emergency-brake with hand-made handle, designed and manufactured by Backman:
http://www.itsfun.nu/if3/if3_045.jpg
http://www.itsfun.nu/if3/if3_004.jpg
PorscheGuy79 04-04-2006 04:19 PM
Backman looks so proud!
Goran, looking real good bud. That is some MEAT on those tires...but it is only matching that beast of a motor. Nice work.
beepbeep 04-07-2006 11:49 AM
Pictures from the shop. I wasn't there during the week, just relaying what guys did. I'll try to do some work tomorrow though.
Trunk is clothed and oil-lines drawn (not sure if I like return hose to oil tank pre-warming brake fluid reservoirs, I'll try to change that):
http://www.itsfun.nu/if3/if3_055.jpg
http://www.itsfun.nu/if3/if3_056.jpg
Interior is being clothed:
http://www.itsfun.nu/if3/if3_058.jpg
The car right now:
http://www.itsfun.nu/if3/if3_063.jpg
Door panels are being covered by small synthetic fibers. Dunno what it's called in english. We call it "flocking".
Car rolls on it's own wheels for firs time this year:
http://www.itsfun.nu/if3/if3_069.jpg
beepbeep 04-09-2006 12:39 PM
Heat insulation for engine-bay (what's left of it) and oil-tank up front:
http://www.itsfun.nu/if3/if3_101.jpg
http://www.itsfun.nu/if3/if3_096.jpg
Coupe starts to look like something:
http://www.itsfun.nu/if3/if3_091.jpg
By the way, car is painted champagne-metallic. Ignore the tires, they are only there so we can roll the car. They might come to use some day on the strip though ;)
http://www.itsfun.nu/if3/if3_075.jpg
New product idea? A carbon fibre bra:
http://www.itsfun.nu/if3/if3_062.jpg
beepbeep 04-09-2006 12:47 PM
Jürgen, our engnine managment wizard, is connecting the oil-lines:
http://www.itsfun.nu/if3/if3_087.jpg
Time for a lunch:
http://www.itsfun.nu/if3/if3_093.jpg
Time to install the instruments (no, they aren't original ;) ):
http://www.itsfun.nu/if3/if3_102.jpg
Everyone is busy:
http://www.itsfun.nu/if3/if3_121.jpg
I got to do thing I hate the most: cleaning and re-packing CV-joints :mad: Luckily, CV-joints actually belong to excavating equipment and are quite easy to disasemble and repack. Shafts are custom made from spring-steel.
http://www.itsfun.nu/if3/if3_122.jpg
Rear wing is mounted, Tokan is going to apply putty, polish it up and re-paint.
http://www.itsfun.nu/if3/if3_127.jpg
beepbeep 04-09-2006 12:52 PM
Pedals are slightly re-done with adjustable brake bias and hydraulic clutch:
http://www.itsfun.nu/if3/if3_128.jpg
Instrument panel is sawed up to accept new instruments with dash-logger etc. Made by Andreas:
http://www.itsfun.nu/if3/if3_130.jpg
http://www.itsfun.nu/if3/if3_129.jpg
Torbjörn (who is actually a race-engineer) is doing last fibre-glass sheet reinforcements on front hood.
http://www.itsfun.nu/if3/if3_119.jpg
Clear explanation to a welder about where to weld wastegate openings (translation: Here - Not here):
http://www.itsfun.nu/if3/if3_068.jpg
Rims (no pun intended) are polished into bling-bling shine:
http://www.itsfun.nu/if3/if3_078.jpg
beepbeep 04-09-2006 12:55 PM
There are only four days left before car exibition and car should be fully driveable before that, so expect lot's of updates in following few days! ;)
Work is now being done almost around the clock, Many workers are actually volunteers from Zatzy.com, biggest Swedish car forum.
PorscheGuy79 04-09-2006 01:27 PM
Oh, its gonna be a good week for me. :)
87coupe 04-09-2006 01:45 PM
^ More pics of It's Fun 3 please ;)
Plecostomus 04-09-2006 03:51 PM
Where do you guys get your energy?
