Detached Member
Pulled my rear sway bar off of its bushings,the two brackets that bolt to the frame, when I dropped my motor and trannie. Now I can't get it back up to the mounting position, even using a jack, it stops about 2 inches below where it belongs. Did this with the car on jack stands on the torsion bar covers. What am I missing.
Hugh |
If I recall correctly you can attach either at the drop link or the bushings first, then lower the car so there is weight on the wheels. Should just bolt up then.
Tony G 2000 Boxster S |
Never had any problem on mine. Stock size?
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
More Likeable IRL
could the drop links spun around the opposite way and you got it flipped over? it is a later g-50 bar it may be holding up on the tranny?
just spit balling here, you know see what sticks.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
