IAN IAN is offline
Torque Value for top Nut that Secures Shock?
What is the torque value for the large nut that secures the shock.
This is the nut that is inside of the front trunk.
I have Boge struts with bilstein inserts.
1972 2.4 T
Thanks,
Ian
Old 01-05-2006, 01:39 PM
Cannot answer your question, Here is what I do:
I count the number of threads exposed above the nut before I take it off, and make sure the same number of threads are exposed after I put it back with my air impact wrench.
This only works if you are not swapping struts types, kinds, and others.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 01-05-2006, 02:45 PM
Autodidactic user
David E. Clark's Avatar
Here are all the tightening torques for the front axel and steering. Hope it helps.
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions.
1973 911E Targa (MFI)
Old 01-05-2006, 03:36 PM
IAN IAN is offline
One More Torque Value Question: ball joint wedge pin?
What is the torque value for the wedge pin nut that slides through the bottom of the strut?
I see 2 values on the chart below: 32.5 and 15.9
I used the higher value of 32.5.
Anyon?
Old 01-05-2006, 03:54 PM
Autodidactic user
If it's the castellated nut, like this:
then it's 32.5 otherwise it's 15.9.
Old 01-05-2006, 04:02 PM
IAN IAN is offline
It is the nut that secures the wedge pin which attaches the ball joint to the strut.
If I over torqued should I leave alone?
Back it off and re-torque?
Ian
Old 01-05-2006, 04:04 PM
Autodidactic user
I'd back off and get the torque correct. There is a big difference between the 32.5 and 16!
Old 01-05-2006, 04:09 PM
