RideShoot&Drink's Avatar
Send a message via Yahoo to RideShoot&Drink
Originally posted by 911teo
Keith and Aaron at Zuffenhaus are the expert. I know th G50 is longer and wider. U need to modify th eTbar housing and modify the tunnel.
I'll ask them to chime in for more precise infos...
Thanks Matteo, any info would be greatly appreciated!
P.S.: it seems like in the end, you wouldn't have to adjust to a different exterior color!
I'm in heaven, when I drive my nine eleven...
Old 02-26-2006, 02:28 PM
Brother's Avatar
What is different/better about the 935 suspension?
What does it allow you to do?
Paul
1980 911SC Targa - Sold
1972 914 - Sold
Old 02-26-2006, 02:54 PM
m325ix's Avatar
this is awesome ! I know the feeling, keep the faith !
http://www.mybuildgarage.com/author/carreraboy
Old 02-26-2006, 03:09 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Matteo,
very nice project. It seems like money for sure isn't an issue or a limiting factor in this built. What is the entire budget you have planned for this?
Just adding up a fully built 3.9 engine with MOTEC, massive tub mods, full 935 suspension, paint, new donor tub, etc. I am wondering if you could almost buy a 997 cup car outright instead....
Keep us posted with lots of pictures on progress.
Cheers,
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 02-26-2006, 03:39 PM
Friends of Warren
911teo's Avatar
First of all I had to replace the whole front suspension. A-arm, struts, cross member etc. so I thought that if I ever wanted to do the ERP kit now was the time...
As per the advantages the main benefit is adjustability. Camber, caster, track width can be easily set. Also you get rid of the cross member as the ERP has its own. The arms are longer and the pivo point is raised to improve camber and reduce anti-dive tendencies under braking.
Will I take full advantage of this? I doubt it.. at least initially... But it's there and I can only get better.
These are a couple of pics to see how it will looke when installed
From the Rennspeed website
And on the car from autometrics
Matteo
Warren RIP
www.impactbumpers.co.uk
Old 02-27-2006, 04:57 AM
Jon Merck's Avatar
Matteo, What an awesome car! When do project completion on this?
Jon
Old 02-27-2006, 05:12 AM
Friends of Warren
911teo's Avatar
Thanks my friend...
I would say that the car with the old 3.6 could be ready by the 3rd week of March...
The 3.9 engine will take a little longer... I certainly hope to have it all done by Easter
Matteo
Warren RIP
Old 02-27-2006, 05:14 AM
Jon Merck's Avatar
We'll have to schedule a "Spring Run" for this monster. Looking forward to seeing it in person.
Jon
Old 02-27-2006, 05:24 AM
Friends of Warren
911teo's Avatar
Originally posted by ischmitz
Matteo,
Cheers,
Ingo
Ingo
I don't know about a 997 cup, but certainly I am in 996 GT3 territory.
But the way I see it is that since I am not a pro this has to be first of all FUN.
I know I could have bought a faster, more powerful, newer car for less money...
But my car will be something special.. something different, almost unique. I will have decided every details of it...
It was not meant to go this far.. I just wanted to fix mine after the crash and get it back on the road asap....
When I learnt that it would take a while to fix the tub I thought abt "upgrading" the 3.6... I had some time and some spare cash... And the rest is history...
A little better here, a little cooler there, no budget and I ended up with this.
Sometimes I wonder if I went a little too far. In the quest of making this the ultimate fun 911 I might have created a "monster" and messed up the "balance". it takes more than a hugely powerful engine and light chassis to make a good car.
We'll see...
Matteo
Warren RIP
Old 02-27-2006, 05:41 AM
Friends of Warren
911teo's Avatar
Jon
anytime... I'd love to have a spin on yours too...
Matteo
Warren RIP
Old 02-27-2006, 05:42 AM
Fl Ted's Avatar
The ultimate "as long as I'm in there" 911!!
Porsches: should be on the governments "controlled substances" list!!!
'86 Carrera Cab "The Grey White Whale"
'98 Kirkham 427 Cobra(in rehab)
'94 Dodge Intrepid ES(very Porsche-like)
'99 F-250 SD Diesel(Cowboy Cadillac)
Old 02-27-2006, 07:17 AM
Sports Purpose 911 Driver
mjshira's Avatar
the ultimate 911 is the one you own IMHO. Matteo, your car is unique !
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 02-27-2006, 05:18 PM
Brother's Avatar
[QUOTE]Originally posted by 911teo
[B]First of all I had to replace the whole front suspension. A-arm, struts, cross member etc. so I thought that if I ever wanted to do the ERP kit now was the time...
[QUOTE]
Cool, I didn't know that. Those are the first pictures that I've seen. You do have to get coil overs in the front though, but you already talked about that with the spring perches and all.
Are you doing coil springs in the back? Does the ERP stuff do the same thing in the rear?
What the heck does ERP stand for?
Thanks for humoring my questions.
Paul
1972 914 - Sold
Old 02-27-2006, 06:56 PM
Jeff Alton's Avatar
ERP is Eisenlohr Racing Products (sp). The fronts are remarkably abjustable, I run it on my car too. You have all the regular adjustments at the top of the strut (even moe if you get plates like Matteo is using) plus you can adjust caster and camber/track width under the car in a matter of minutes or seconds if you are fast!! The stuff is substantially lighter as well. ( thom and randy's database has the weights)
The rear allows you to adjust the toe by lengthening the plate with the big adjuster at the pivot point, very easy. It also adjusts idependant of camber. Once again, this only takes seconds as you don't loosen the rear bolts that mount the spring plate to the trailing arm. I *think* Matteo is using camber boxes for the trailing arm pickups, and this is the ultimate set up as it allows you to adjust camber from inside the car (rear seat area). I don't have the rear pivot boxes (yet) but would sure like them!
Matteo will have the ultimate (IMHO) suspension set up depending on what he does for sway bars. It will have a HUGE range of adjustment (think 3 times what a stock set up has), be very compliant, with absolutely no movement due to rubber pieces. The only rubber in this setup is in the tires.
Nice choices on the products my friend! I love it!
Cheers
www.turn3autosport.com
Old 02-27-2006, 08:40 PM
Brother's Avatar
Thanks Jeff
Paul
1972 914 - Sold
Old 02-27-2006, 08:51 PM
Unsafe at any speed
Nader's Avatar
Incredible project. Will you still be taking it to the track? You haven't left anything to improve if you wreck it again!
87 Carrera Coupe
Old 02-28-2006, 02:18 AM
Brother's Avatar
What is the piece that parrallels the struts and comes down to the a arm? That isn't in the picture of the suspension.
Paul
1972 914 - Sold
Old 02-28-2006, 03:58 AM
I'm with Bill
Jims5543's Avatar
Thanks my friend...
I have a vacation home in Western NC. A fellow Pelican and I plan on some fun mountain runs this spring and summer. We would love for you to come over and cruise with us.
1978 Mini Cooper Pickup
1991 BMW 318i M50 2.8 swap
2005 Mini Cooper S
Old 02-28-2006, 06:02 AM
PorscheGuy79's Avatar
That is a through body sway bar.
Matthew
“Sometimes the questions are complicated and the answers are simple.”
Old 02-28-2006, 06:05 AM
Friends of Warren
911teo's Avatar
I didn't know myself.. you learn everything new every day
... I *think* Matteo is using camber boxes for the trailing arm pickups, and this is the ultimate set up as it allows you to adjust camber from inside the car (rear seat area). I don't have the rear pivot boxes (yet) but would sure like them!
I am not ready to lose the rear seats yet.. The 2 little helpers above love riding in the back of Papi's (daddy in Italian) Porsche.
I am thinking of a way of welding camber boxes there without losing the rear panel. We (well the guys at Zuffenhaus) are goig to make some major mods to the tunnel and rear seats area to fit the G50/31. So maybe we can find a way to get the camber boxes in there too.
I have a pair of The Racers Group sway bars. I destroyed the drop link in the accident but the rest is still re-usable. I love them as it is really easy to adjust them.
Thank you!
Matteo
Warren RIP
Old 02-28-2006, 06:54 AM
