Question Testing O2 Sensor
My 86 Carerra is running unbelievably rich. Horrible gas mileage (even with my foot off the gas). I suspect the O2 sensor is going bad. Is there a way to test it before popping for a $220 test?
Thanks in advance
britt
Old 01-18-2006, 10:08 AM
02 sensor will not make your engine run that rich but an easy test: unplug it and see if it makes a difference.
Joe
Old 01-18-2006, 11:30 AM
A Bosch generic replacement shouldn't be more than $60-$80. A search will yield lots more info.
Warren & Ron, may you rest in Peace.
Old 01-18-2006, 11:38 AM
Bill Verburg's Avatar
Check the voltage there are 3 wires, black is the sensor signal which should fluctuate between 0.1 and 0.9 Vdc
If you connect in the harness it is the green wire.
Bill Verburg
Old 01-18-2006, 02:25 PM
Early_S_Man's Avatar
Porsche Crest
Don't just hang any old meter or test lamp on that O2 sensor wire, either!!! The test instrument MUST have 10.0 Megohms or greater input impedance ...
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 01-18-2006, 02:33 PM
