Tut Tut is offline
Bilstein/Boge insert questions
Two questions:
When I opened the Bilstein box there was a rubber ring that goes over the shaft or strut rod. About 1/8th to 3/16ths thick. Does it go under or on top of the dust shield, or does it go elsewhere?
Where can I get one of the wrenches used to tighten the ring that locks the insert into the strut? I'm sure there are other ways to do it, but I wouldn't mind having the wrench.
Thanks.
Tut
'87 Carrera coupe
'08 BMW 535 xiT
Old 02-27-2006, 09:39 AM
The search will work wonders: 87 Shock and Strut installation tips
Warren & Ron, may you rest in Peace.
Old 02-27-2006, 10:17 AM
Nine9six's Avatar
In answer to your question: Cut and pasted from the link RickM supplied.
The Bilsteins come with a small rubber ring fitted around the shaft to keep the cover in place during shipping. You will not be using this in the install, so just throw it away.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 02-27-2006, 10:33 AM
