Recreational User
I'm probably going to try the Rubbermaid Solution this summer just for giggles. If it works, maybe Grady and I can put it on a dyno and document the advantages of it on a 3.2 Carrera. And Ryan....unemployed? Never! I'm just, um...resting between jobs.
Recreational User
Einstein, Da Vinci and the Wright brothers were in the first group.
Registered Usurper
My Dad always drove Detroit V-8's. One thing he told me, when teaching me how to drive, was to turn on the heater full blast if I'm in a situation where the engine is heating up, that this might slow the temp.rise untill I could stop safely and see what the problem was.
I know it worked in his 51 Olds 88, because it happened to me and it got me to a country gas station 10 miles or so down the road w/o burning up the engine. Seems to me that might work even more effectively on an air/oil cooled engine.
'82 SC RoW coupe |
Information Junky
"Genius is one percent inspiration and ninety-nine percent perspiration." Thomas A. Edison.
Edison tried all kinds of stuff "outside the box" . .. and threw it in the bin. There is a difference between discovery and engineering, BTW. Both methods may lead to a solution, but, the engineer is well versed in previous discoveries . .. AND how to optimize their effect(s). --That's a pretty big box!
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
island, that's the first post from you I recollect seeing in a helluva long time! Have you been hibernating?
Good to see it, ianc
BMW 135i. Nice. Fast. But no 911... "I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79 |
thx for reply. Have you ever checked your spark plugs after these hottie runs ? If not it may be advantageous to monitor them ? Personally I'm combustion neurotic in a learning sort of way. also another oil cooler can go under left fender.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 Last edited by RoninLB; 03-24-2006 at 11:39 PM.. |
Information Junky
thanks.Just waaayyyyy too absorbed in too many projects. Busier than I want to be. . .and I'm really kicking myself for not having time to see all those cool engines at Waynes open house. You Californians have got it good!
To keep the motor cool when temps are rising, Grady Clay has suggested keeping the rev's up to keep a large amount of air flowing over the cylinders and heads. A front mount cooler is really key in this situation so that you can use speed (and reduced engine load) to reduce temps, on cars w/o front mount coolers it is hard to reduce oil temps once they have risen, because the engine mounted cooler is all there is. |
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
ianc
Banks tech talk
Cool Air Equals Power Cool air is good for making power, but could hot air be even better? http://www.bankspower.com/tech_coolair.cfm Quote:
The Banks Super Scoop, as shown on this Ford V-10 gasoline engine, provides both cool air and a mild ram-air affect. The Super Scoop also incorporates a water drain to separate any rainwater from the airflow entering the scoop.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
Greater fuel than should be necessary for power will cool the heads. It's not so much that the fuel absorbs heat as we would simply think. It's that the greater fuel slows the speed of the flame combustion event producing power at the piston. This could also be created by retarding the ignition timing instead of dumping fuel. So instead of cooling the heads from greater oil cooling a wrench could install maybe $8k of EFI.
Meanwhile hot heads at high hp output makes denotation a possibility. Burned exhaust valves is bonus coupons. Grady's thoughts relate to cooling the heads. If it can't be done simply by greater air flow then it has to be done another way.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
And what about cars that have a radiator and an oil cooler??? Are they both water cooled and oil cooled as well??? Ok, this thread is getting too philisophical for me.
Proud Owner: 1996 C2 Cabriolet (993) 1988 944 SOHC 1998 Ford Ranger XLT (Total P.O.S.) 2005 Specialized Allez Comp 27-speed (yes, it's a bicycle!) My Porsche page (I know, kinda lame. Just wait until I learn Dreamweaver) http://members.cox.net/kronowit/porschepage.html |
It's simple. You need combustion for power. Combustion needs an environment. You engineer the environment.
>"The world is divided into two groups: those that believe in the impossible >and those working on the improbable. Pay attention, so you end up in the >second group."
Now's a fun time to point out that thermodynamics only applies to systems in equilibrium... and thus definitely not to our cars. In a non-equilibrium state there are plenty of examples of the "laws" being broken. Keep the ideas coming Dave! Babak |
ryan
ianc,
Pelican kobaltblau and I are going to repeat ryan’s experiment this summer. I’m going to measure the head temperatures and the temperature of the oil as it is first pumped out of the engine. We are going to try this with fairly controlled road conditions and on track. Aside from the speed issue I want to have some quantitative data using the Rubbermaid Solution. Once we have that repeatable, Andy wants to change the crank pulley to turn the fan 1.82:1. We will then repeat the measurements. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
Hi,
Just to add to the quote contest: One should always keep an open mind, but not so open that the brain falls out. |
>Only if you fail to define a control volume.
Jim, did you know Jarzinsky when he was at Los Alamos? |
grady,
looking forward to the results of your more controlled study. btw, i never did change my fan ratio..of course it being winter, i'm happier with my 'slower fan' for the time being. but just wait until july..then august..![]() ryan
