kwm kwm is offline
Upgraded more modern fuse box
Is there any kind of upgraded more modern fuse box made for a 911. This POS fuse box in my SC just isn't going to cut it. I have never seen it but if a more modern replacement fuse box exists I am buying it. Anyone?
83SC black on black
01 Chevy S10
08 Buick Enclave
Old 05-12-2006, 11:35 AM
Considering such an upgrade myself.
Click here>>>Painless
Old 05-12-2006, 11:40 AM
kwm kwm is offline
so is there anything avail.
83SC black on black
01 Chevy S10
08 Buick Enclave
Old 05-12-2006, 11:46 AM
randywebb's Avatar
yes if you do some DIY - search and you'll find the info
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 05-12-2006, 11:53 AM
Try a search...this was a hot subject a year ago and a few guys posted some slick replacements they did.
Fritz
1987 944S
1973 911E
Old 05-12-2006, 11:54 AM
Uhhhhh.........did you click the painless link above? It doesn't get anymore available than that. Other options from 3 to 18 circuits available at Summit.
Old 05-12-2006, 12:00 PM
If you find the thread, it may have mentioned waytek.com. They have 4, 6, 8 and 12-place ATO-type fuse boxes that have a similar configuration as the factory box.
Keep the same fuse/circuit positions so as not to confuse the next PO or your favorite diagnostic tech. Do it neat and tidy like the factory did.
Sherwood
Old 05-12-2006, 01:01 PM
kwm kwm is offline
Some in the other thread who is doing this or poss. had already done it said he repalced all teh wires he could get to in the trunk area. What would be the point in that? running good new wire to old weathered wire????? That woudl actually make a bad sitaution worse would it not?
83SC black on black
01 Chevy S10
08 Buick Enclave
Old 05-12-2006, 01:04 PM
cali74's Avatar
Often the only bad part of the old wire is near the ends. With many connections in the trunk area, replacing all the wires up there avoids having to cut back each individual wire to determine where it seems "fresh" and where is seems "old".
Oh yeah, other reason for replacing wires up there is current flow issues, like if you needed to run bigger wire to the headlights.
That is my guess why someone would replace the front wires and connect them to the wires running to the back. Additionally, the wiring harness that is in the front trunk doesn't all route through the tunnel, so you could replace the harness in sub-sections if you wanted to.
74 911 with '95 3.6l
Old 05-12-2006, 01:49 PM
scottb's Avatar
This thread might be helpful. Fred Cook did a great job on upgrading his fuse box.
1984 Targa
Old 05-12-2006, 01:59 PM
Check these links:
ATO Fuse #1
ATO Fuse #2
DUK DUK is offline
DUK's Avatar
Check out american autowire. I've got one of their wiring harnesses and it is awesome. Had to buy it through watson-streetworks.
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 05-12-2006, 02:03 PM
One more good one:
ATO Fuse #3
Search under "fuse" with user names "Fred Cook" or "Ove" for more.
Old 05-12-2006, 02:04 PM
beamonk's Avatar
Send a message via AIM to beamonk
I just met a long lost cousin who works for way-tek. If I can get her some specs, she might be a source.
John Brasfield
91 C2
78 SC For sale
76 3.6
68 Datsun 2000 Mr. Magoo, 02 330ci
Old 05-12-2006, 03:44 PM
randywebb's Avatar
Give her a ride and a bottle of wine -- see if they will custom make something...
Old 05-12-2006, 10:20 PM
I don't see a need to customize much if at all. Almost looks like the factory fuse box except for the missing suppository cartridge fuses.
Sherwood
Old 05-12-2006, 10:35 PM
randywebb's Avatar
ah.... I have a '73 (the two vertical fuse strips)
Old 05-12-2006, 10:46 PM
"ah.... I have a '73 (the two vertical fuse strips)"
Randy,
Okay, how's this?
All seriousness aside, what's the issue?
Sherwood
Old 05-13-2006, 12:00 AM
beamonk's Avatar
Sherwood is right, it looks like an easy fix with the wavtek stuff. 30 amp capacity. I will see about getting some stuff!
John Brasfield
91 C2
78 SC For sale
76 3.6
Old 05-13-2006, 06:18 AM
Anyone have a direct link to the fuse block? I found wavetek but no block.
Old 05-13-2006, 06:48 AM
