Can't get spark -- grounded points?
A friend is trying to resurrect an engine that has sat for a long time.
He's tried everything to get spark, but the spark only happens as the ignition key rotates from the starter position to 'on.' There's no spark while cranking. I've put a VOM on the points and the arm of the point set seems to be grounded (as is the base). I've never dealt with this kind of problem before, and I don't know how to advise. We've switched point sets; same issue. Any thoughts?
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
That's correct the points make and break a circuit to ground. Sound like an issue in the ignition switch.
Check the B wire in the CD box harness(middle one) for +12v
Thanks, Bill. I'll drop over later today and check that.
Drive Nürburgring !!!!!
Hi techweenie !
I just had the same problem 2 weeks ago on my 911T from 70 but with a 77 engine ! ! I turned the engine by hand with ignition on and every time the point's opened i got a spark but not when i cranked the engine !! So i took a wire connected it to the fuse box in the trunk and hooked ít up to the CDI ! The car started right away !! Hope this will help !! Greetings
78 ,911 Targa 3,2ltr 63, 356 B Racer The Nürburgring Tool 04. 996 GT3 Euro CS ( German Based ) High Tech 427 Sebring 12 hrs Cobra |
Old Member
Bill
I've seen this happen with older cars with bad wiring connections or a less than full charge on the battery. Bad ground connection or poor contact with the connections at the starter. Ignition switch also.
Clifton Brown https://www.mancalamarketing.com |
