So have any of you "do it yourselfers" found a economical way to replace the lens on 84-89 fog lights? Also why are they heavy? Anyway to lighten them up a bit?
Frank 1980 SC Cab Conversion (sold) 1974 914 2.0 RIP rear ended Looking for a 996 Silver Cab 2002-2004 |
Wash. State
Oops! My bad, as one might say....
Mondays can really be Hell........... Last edited by nesslar; 06-19-2006 at 03:22 PM.. |
rip 'em out and use the hole to cool the brakes
Search for ZOANAS and I think Wil Ferch on this board. They did install some other lights.
If you don't use them though, do what nostatic says ![]() I still use mine. -Chris
1987 Guards Red Targa (sold) 2006 Toyota Tundra DC 4x4, the "man-e-van" 1998 CR500 Well on the fringe...... |
MBruns for President
Picked up my car from it's tech inspection and oil change -
It's running like a top - Got home and one of my fog lights had a little breakerage... No problem - I have been working on a project anyway to add some more fresh air to the brakes and carrera oil cooler. Looks like a stock carrera - Stainless Steel mesh epoxied to the inside of the housing APC driving light mounted to the inside Lights on with the flash to highlight the guts
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Pretty cool trick there JeremyD thanks for the tip
JeremyD,
I' ve seen something like that at any autopart store but never know if they really light up the road. How are their visibility? Thanks.
Fat butt 911, 1987 |
As well or better than the existing fogs, which are maginal at best. I just went with the standard driving lap - being low like that does not help on the driving light end... But definitely better than stock
Last question regarding foglight, I went to autozone and found your type, also saw they have something with projector lense look like the pic below.
Do you know if the one with projector lense would give more lighting visibility? Thanks.
UFLYICU
Somebody call?? These are Hella 450 driving lights. I do a lot of night driving, and they are flamethrowers. 1 mile pencil beams, and with my relay setup, I can use them with my high or low beams.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
Mad scientist
A pair of these might do the trick. Carbon fiber air ducts, weighs just 200 grams each.
/Peter
'84 911 Carrera '91 928 S4 You can't make a racehorse out of a bull, but you can make an awfully fast bull. |
Any ideas? |
Nevermind, we got it all figured out, and those 450s are Amazing!
UFLYICU
Yeah, be prepared to get flashed if you forget to shut them down for oncoming cars. They will burn holes through trees.
