LinkBack Thread Tools Rating: Thread Rating: 4 votes, 4.00 average.
89 930.
Benny771's Avatar
Originally Posted by JohnJL View Post
How about the "rubbermaid trick" set up on your condenser? Would that work?
???? What is that ????
Old 07-09-2012, 08:35 PM
wwest's Avatar
Originally Posted by Motorhead-45 View Post
I bet half of you who opened this post thought I had the answer...no such luck! I'm looking for the holy grail on front a/c condensor performance improvement. The question is.. Has anyone successfully improved the performance of their front mounted 911 a/c condensor? I've done a search and seen lots of info on people asking the question but what I haven't found is someone who has achieved success. Specifically looking for info on anyone who may have found a way to better duct air to the condensor, found a way to get the condensor in the airflow of a moving car, found a better fan, or found a way to successfully speed up the fan. I've come to the realization that I'm at the point of being "condensor challenged" and would like to exhaust all innovative ideas on the stock condensor before I start spending more money on new replacement condensors. I have to believe that someone out there has figured out how to get more airflow to the condensor in it's stock or nearly stock location? Even if I eventually spring for one of the new serpentine front condensors I'm sure it would benefit from better airflow than the stock setup.
It's 93 degrees today and 74 percent humidity......
Help!
I added 2 electric radiator cooling fans, ~$50/Ebay, to provide more consistent airflow downward through the engine lid condensor (and the engine). They run in series with the A/C system on and in parallel when the compressor clutch is engaged.
Removed the fuse from the front blower.
Thinking of shipping it off to my nephew in the Memphis area to confront the many naysayers "here".
'88 Carrera.
Old 07-09-2012, 08:49 PM
Go-Kart Mozart
JAR0023's Avatar
Old post but I'm working on something for this so I'll play along. MY 86 is all original and works, just not very well. I'm seeing 55* vent temps with ambient in the high 90s. I've been looking at ways to imporve performance incrementally without breaking the bank.
Recently discovered my front condenser blower motor seized. No fuse and I said a small prayer that it hadn't caught fire. Original plan was to replace the motor but the squirrel cage came apart on me as well.
I have a replacement unit coming from a fellow Pelican, but I figure I'll play around with the housing I have and see what can be done. Searching here it looks like the footwell blower motor is the same size and will fit in the con/blower housing but supposedly spins faster(more air flow).
I found a Fasco squirrel cage that is a little larger in diameter than the eom unit but looks like it will fit. Width wise it's good. I scored a pair of footwell blowers from eBay so I'll try that motor with the new cage.
There is also a thread here(sorry my links are on another compter) where a member sliced the motor area off the housing and bolted up a generic DC motor. Been scouring the internet for a suitable replacement motor but haven't found one cheap.
I'm about to head out for family vacatoin for two weeks. Should have stacks of parts waiting when I return. If I get anywhere with this I"ll post up again.
J
Old 07-09-2012, 09:22 PM
fred cook's Avatar
Front condenser...........
I have a front valence with the opening for an oil cooler. Since I have a large Setrab cooler mounted in the right front fender, the need for a front mounted oil cooler is non existant. I have thought of moving my front condenser to the spot where a front oil cooler normally lives and add a couple of small fans behind it. Haven't done it yet, but that's the plan.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 07-10-2012, 05:01 AM
Uno Dei Molti Porschisti
BarryJB's Avatar
I replaced just the motor in the front condenser blower with a footwell blower motor - trade over the squirrel cage (rebalance if needed, bit of patience) and I think some minor mods to the electrical connections (I forget if it was a polarity or terminal-style issue, either way I don't remember anything dramatic was required) - otherwise mechanically it's identical...
Why bother?
'cos the footwell motors run at higher rpm than the condenser motors.
Noticeably louder but definitely made a difference. I'd already added a double-thick front condenser 10 years ago, although I'm sure the newer designs work even better, and converted to R-134a and added a trinary switch to compressor port to protect the installation, especially useful until I'd finished replacing all old leaky old hoses. Also added a foam seal around the top perimeter of the front condenser to force more fan/ram air to flow through it, not sure how much difference it made but seemed like a good idea at the time.
At center-console vents & home-made lower straight vent (where butterfly used to go), temps down to mid-low 30's on high fan speed in low 90's ambient here in SoCal. Just gone to a 3.6 so not reinstalling a compressor until I've got the oil cooling where it needs to be, but BAC the newer evaporators are a good way to go too re overall A/C performance, plus I'll add a fan to the engine lid condenser via the trinary.
I tried several things such as series/parallel stacks of electronics cooling fans and surplus squirrel cage blowers, but never found anything alternative that either had more cfm than OEM or would fit the space. Maybe those "electric turbo"/model aircraft/brake duct fans that install into SCAT, SKEET or other circular duct setups might work well for stuck-in-traffic, need a big relay though!
Never tried the "Rubbermaid" idea but would probably help in lower humidity areas. Not very convenient though to have to carry all that deuterium water in the luggage compartment for a daily driver though, plus swamp cooling the condenser not very p-car like... sort of same ilk as the window-mounted ice-bucket "mommy coolers" old-timers have told me you could rent at gas stations in the Dark Ages - but wait, there's an idea - probably more effective than stock pre wet 911 A/C
85 Carrera Coupe, OBD-I 993 3.6 conversion (bottomless list of mods)—425k+ miles. 100k on the 3.6, zero blue smoke, but oh the leaks... two broken 915s But G50 and all the other bits going in early 2024
Consolation & stealth vehicle: 05 Mercedes E55 AMG S211 "No one will suspect the Spa... silver station wagon".
Old 07-10-2012, 04:53 PM
It took only 49 years!
mclmk8d's Avatar
'88 Carrera.
Can you tell me more about the fans you added in the rear? Do you have photos of the install?
Serge: In the heart of Philly!
Daisy - 1972 911T 2.7L Light Yellow
Veronica - 1987 911 Carrera Coupe Indischrot, M&K GT3 muffler and Euro Pre-Muffler, SW Chip SOLD
Lil Blue - 2002 Subaru WRX Wagon (my dd/HPDE car) SOLD
Old 07-11-2012, 01:11 PM
brads911sc's Avatar
Lol
Originally Posted by mclmk8d View Post
can you tell me more about the fans you added in the rear? Do you have photos of the install?
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 07-11-2012, 01:16 PM
mclmk8d's Avatar
Originally Posted by brads911sc View Post
Lol
yeah, I know, Brad, it sounds like a Wile Coyote thing or worse!
Old 07-11-2012, 01:28 PM
brads911sc's Avatar
I am all for creativity. But what works in the Pacific Northwest with 74-81 degree July ambients, will NOT work in Florida or anywhere on the gulf coast with 90-96 degree ambients and high humidity.
Its silly for WWEST to even present that as a viable option in any location where the average daily ambients in June - September is 90-96 degrees when his mid July mid afternoon temps are 74-81 degrees.
Old 07-11-2012, 02:24 PM
CharlieB's Avatar
After doing a complete AC upgrade on my 80SC the only piece missing was improving the front condensor fan. I replaced the old slow condensor fan motor with a stock main fresh air blower motor. More RPMs. Lots more CFM and fit the stock housing and squirrel cage like a glove! Don't forget an inline fuse for safties sake!
Old 07-11-2012, 02:33 PM
brads911sc's Avatar
Great Idea.
Do you have the Part Number for what you ordered?
Old 07-11-2012, 02:34 PM
[QUOTE=fred cook;6848746]I have a front valence with the opening for an oil cooler. Since I have a large Setrab cooler mounted in the right front fender, the need for a front mounted oil cooler is non existant. I have thought of moving my front condenser to the spot where a front oil cooler normally lives and add a couple of small fans behind it. Haven't done it yet, but that's the plan.
You mean like this? Yes it works, once moving it really cools very well. I've been thinking of going to a more modern serpentine from griffiths here but I don't know if it will fit.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 07-11-2012, 03:49 PM
CharlieB's Avatar
I don't have a part number but I know our host has them in the catalog. I just disassembled an old fresh air blower assembly I had on the shelf. Pulled the motor out and took off the blower cage. Same with the front blower assembly. Hardest part was separating the front cage off the motor shaft. Tested both motors side by side to confirm that there was indeed a difference in RPMs between the motors.
Old 07-11-2012, 04:19 PM
A few more cents: I have read somewhere in these forums that the footwell blower motors are exactly the same size as the front a/c condenser blower motor. They are supposed to have a higher rpm rate for better air flow, but are also a bit noisier- mostly noticed at stop/go city driving speeds. I have seen the footwell blower motors on ebay- new, for about $75 as I recall.
Tim
Old 07-12-2012, 12:33 AM
BarryJB's Avatar
Tim
See my post 50 above, and 19 in an older thread where I'd first mentioned using footwell motors in condenser - "Anyone ever update their vent/AC system to 86+?".
Also correction that with the system on my 3.2, low 30's in 90's only on low fan speed - high yielded 40's.
Our host lists the fresh air blower motor w/squirrel cage, etc. - 911-571-320-32-M6. Just the motor, I had a number jotted down, Bosch R2031-12430.
For some $50 Dayton 3LCH7 can be adapted to replace the engine blower (I and many others have done this), condenser and footwell blowers, and probably the fresh-air blower too, some mods to housings. It runs at 2350rpm. In previous threads, no-one seemed to have any rpm data on the various blower motors, but since replacing the condenser motor, have procured a non-contact tachometer, so next time blower bits need work, I'll take some measurements.
At least one thread here has pics of some creative rear condenser fan installs and mention that this helps in traffic/high heat, but I don't understand why one wouldn't keep the front condenser fan as well, FME anything you do to improve that component & airflow through it is worthwhile and conversely, disconnecting it cannot possibly be a good thing (unless it's about to catch fire
Barry
Old 07-12-2012, 03:43 AM
wwest's Avatar
At this moment I am in Missouli MT having driven ~ 500 miles yesterday to get here. OAT was hovering around/above 95F from mid-WA to here, 2 or 3 slow-stop and go construction zones on the MT side. Otherwise speed was kept above 75MPH.
Only problem was the evaporator frooze up coming over the pass.
Even with the blower on low we had to lower windows slightly so as to not be too cold.
Car is Diamond Blue with matching grey interior and windows are tinted to the level WA allows. Once the interior is cooled it pretty much stays that way.
Not Huston or Memphis but climate wise closer than Seattle.
Old 07-12-2012, 08:39 AM
brads911sc's Avatar
Cant prove it but Id think the front condenser is more a weakness than the deck. Not saying every bit doesnt help. Just saying that this will only work if everything else is great.
Old 07-12-2012, 09:14 AM
BarryJB's Avatar
...OAT was hovering around/above 95F from mid-WA to here, 2 or 3 slow-stop and go construction zones on the MT side. Otherwise speed was kept above 75MPH.
wwest, I'm curious as to your engine temps during these cooling periods - does your engine run particularly cool even with A/C on in slow/stop conditions in 90's?
For comparison, my India Red car would also get downright chilly on the freeway (I could run at low fan speed &/or lower the temp control and maintain); if I was stopped for long in traffic, I could keep cool but only at expense of 240-250F engine temp (approaching/on mark above 9-0'clock). If I parked in sun and car got hot, it might take 15-20 minutes on freeway for A/C to start to actually get car cooled off inside, longer around town.
My guess is color might be a big part too - mine's red, your very light and "bluetiful" color has to help over, say, a black car...
But still, how come you disconnected the front fan? Don't you think it would cool even better with that too? You can always lower the temp control and let the compressor cycle, course you might need to add a manual switch on your decklid fans...
Barry
Barry
Old 07-12-2012, 11:21 AM
BarryJB's Avatar
Originally Posted by JAR0023 View Post
...There is also a thread here(sorry my links are on another compter) where a member sliced the motor area off the housing and bolted up a generic DC motor. Been scouring the internet for a suitable replacement motor but haven't found one cheap.
J,
The technique for installing a Dayton Dayton 3LCH7 (about $50) into a footwell blower assembly is described here: (EASY DIY Footwell blower upgrade! - Rennlist Discussion Forums). It maybe be here too somewhere.
The technique would be similar for the condenser. I'm not sure though how the 2350rpm compares to the OEM footwell/condenser/fresh air blower motor speeds, which are all the same physical form (not sure about polarity) and are mechanically interchangeable (as per post 35) in those housings, FME footwell is faster than condenser motor and improves condenser. 3LCH7 is more usually used replace the engine compartment blower... but don't know rpm of OEM there either
Barry
Old 07-12-2012, 11:36 AM
mclmk8d's Avatar
Barry, will the Dayton motor shaft fit onto the cage fan of the front condenser without modification?
Old 07-12-2012, 12:17 PM
