What is the best way to increase brightness in gauges?
I am looking to make the lights in my gauge brighter and came across these LED's on Ebay. They only come in rted or blue so I'm not sure how they would look but would they damage anything?
Has anyone done a upgrade to their gauge lighting and what have you used? Also, just to mention that I am not planning on buying these because I think this guy is way over priced and I am sure I could find these same bulbs for under $1 somewhere on the internet.
Currently own: 1980 911SC slantnose 1991 Honda Accord -daily driver (1991 Honda Accord #2 - just because) 2003 Acura TL Type-S (2006 Honda Odyssey w/ DVD) Gone but missed: 1988 Mazda RX-7 Turbo II (1991 Jeep Wrangler Renegade) 1984 Jeep CJ-7 (1994 Chevy Blazer) 1987 Chevy Corvette (1996 Mustang Cobra) 1993 Jeep Wrangler (1995 Mustang GT Conv.) 2003 Ford Explorer Sport Trac (1987 BMW M6) Future: Hopefully not too far off Ferrari Testarossa (Lamboghini Diablo or Countach) Detomaso Pantera |
Try just replacing your olda$$ bulbs first. It made a huge difference in my guages. If original, they are at least 20-25 years old. There are others here who have upgraded to LED but for me the cost was too much to justify when I needed others parts.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Friend of Warren
What Wayne said. I replace all of mine and while not as bright as what you see on cars today, there was still a noticeable difference.
Kurt V No more Porsches, but a revolving number of motorcycles. |
1. Remove your bulb holders one at a time and clean & polish both the Faston tab and the holder body with HD rubbing compound or metal polish ... until bright and shiny brass is all you can see. Clean the Faston cnnector at each bulb with vinegar and old toothbrush, then rinse with distilled water ... you should see slight 'pink' coloration of the copper in the brass alloy! Put a small amount of Dow Corning 4 or 111 Silicone Grease on the tab and Faston connector and reconnect.
2. Clean the ground tab and connector at each instrument and treat with silicone grease. 3. Replace the bulbs. Improvement should be quite visible!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Administrator
Do a search. There have been lots of discussions on this. The short answer is: there's an expensive way to do it that works pretty well -- and no one's found an inexpensive way that works really well, yet.
Don't waste your time on colored LED lights, though.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
My 75 had the originals and they were ready for the bone yard. Went to the LED ones and have no complaint at all. Purchased form on of our own Pelicans. (If you don't care if (it) is period correct.) JC
Who manufactures these bulbs?
Carl, |
http://www.superbrightleds.com/cgi-bin/store/commerce.cgi?product=755
Look at the very bottom of the page. I bought the ultra white bulbs about 2 weeks ago. In my opinion, there is a slight improvement, but i think brand new incandescent bulbs probably do a better job.
'78 Euro 911SC (Ongoing Project) '83 911 Fashion Grey Outlaw |
LED and white faces NH speedo. Expensive but worth it.
Q.
2004 996 TurboS Cab 2005Cayenne Turbo S 1988 930 Turbo Cab 2004 BMW M3 2007 Range Rover Sport |
Cigars and 911's -- Smile
subscribing to this thread.
[GruppeB # 978] 1978 911 SC ROW (Pure Euro, no DOT or EPA work done..) 1991 Toyota MR2 Turbo (3S-GTE 4Banger Rocket) 2001 Audi - A6 Quattro 4.2L-V8 (love the growl) 2014 Honda Odyssey for the soccer-team/accessories |
Priced-out of Porsches.
If you replace your bulbs with new ones, you should see a big difference (as said previously).
The tungsten heat cycle is to blame for the dull light emitted from old bulbs. The tungsten oxide that gets released from the filament, when incandescent, deposits on the upper inside surface of the glass envelope as a greyish black/mirrored substance. This occurs over years of use. This diminishes the amount of light emitted and notches the tungsten filament, which eventually results in a blown bulb.
Mike SoCal |
Forgive my ignorance... but:
How do you I get to the bulb holders? Do I need to remove the gauges from the dash? |
How many bulbs are required?
If memory serves me, there are 2 different types of bulbs used, depending upon the gauge. The smaller gauges have 2 bulbs each I think, and the tach/speedo each have 3. Once you have the speedo out, turn it over. The 3 bulbs are in their own holders (denoted with a red ring). Pry the entire holder out from the back of the speedo - DON'T TRY AND TWIST THEM OUT BEFORE REMOVING THE HOLDERS FROM THE BACK OF THE SPEEDO. The bulbs have bayonet-type mounts. If you try and twist them out while still in the gauge, the bulb can fall into the gauge (ask me how I know). Follow Warren's instructions on cleaning the bulb holders and replace with new bulbs. And Jack's correct - search. You'll find the actual bulb numbers in prior threads.
Steve My '85 911 Targa ** Hand painted center caps for sale here RIP Warren PCA & Rennlist member |
Good deal, thanks.
This forum is just AWESOME!!!!!!! |
Me like track days
If you have the patience and skill (and possibly new parts) lining the instrument cans with foil tape made a h u g e difference in my old 3.6 -
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
Craig911, What do you mean with lining the instrument cans?
Me like track days
inside the housing - apply HVAC foil tape
Or one could polish or chrome the inside to match the Fuchs... er.. no.
83 911SC Targa Everything I say is my personal opinion, and has nothing to do with my team. |
