rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
How can I tell if my rear calipers are SC or Carrera?
Is there a way to i.d. them by size, markings, etc. They do say ATE.
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 09-03-2006, 06:15 AM
Oh Haha's Avatar
Am I missing something? Your signature says "81 SC". Pretty much makes 'em SC calipers.
Pacific Blue
Wayne
Old 09-03-2006, 06:20 AM
Todd Simpson's Avatar
Measure the rotor thickness. 20mm for SC, 24mm for Carrera.
Old 09-03-2006, 06:34 AM
rs6er's Avatar
The rears were changed at one point and the wrench told me he put in used Carrera calipers in the rear. Since they were gold I didn't doubt it. Now, in thinking back, I don't believe I paid for new rear rotors though. I thought the SC and Carrera rotors were different.
John
Old 09-03-2006, 06:42 AM
Oh Haha's Avatar
Well, that makes more sense. As Todd said, measure the rotor thickness.
Hmmm, you may need to pay your wrench a visit if they turn out to be SC rotors/calipers. You have a nice upgrade if you have Carrera brkes, though.
Pacific Blue
Wayne
Old 09-03-2006, 07:02 AM
rs6er's Avatar
Well, the rotors are about 20 mm. I noticed in removing the caliper that the gold is like paint in that its on the nuts and bolts too, as if it were sprayed.
To add to this, when I was looking for a shop to do my head stud repair, many on this list recommended this shop.
John
Old 09-03-2006, 07:30 AM
Oh Haha's Avatar
Can you post a picture for us? Before we condemn the wrench, let's make sure there wasn't some miscommunication. When I painted my calipers silver, I painted the entire caliper. Gold? Special request color?
Where do the hard brake lines attach? Underneath the caliper or on the top? IIRC. the Carrera's are located at the top. At least they were on wcc's 85 we just worked on last week.
Pacific Blue
Wayne
Old 09-03-2006, 07:39 AM
Bill Verburg's Avatar
Carreras before '84 used the same M calipers/20mm rotors as SC's and most other 911s since '69
Bill Verburg
Old 09-03-2006, 08:01 AM
rs6er's Avatar
The hard line mounts at the bottom. Also, I thought the SC calipers were iron and the Carrera calipers were alloy. This one is definitely magnetic.
Here are some pics:
John
Old 09-03-2006, 09:14 AM
there was never an alloy caliper for the normally aspirated 911 thru '89.
The alloy S was only used on the front thru '74.
Bill Verburg
Old 09-03-2006, 09:26 AM
rs6er's Avatar
Thanks for clarifying that Bill. So what you are saying, I guess, is that the above caliper is from an SC or a "insert answer here" Carrera?
John
Old 09-03-2006, 09:46 AM
It is either an SC M, or Carrera M, the difference is the width of the spacer between the 2 outer halfs, I would need to look up what the different thickness is, but it's easy to tell from the rotors, 24mm Carrera, 20mm SC and other 911. Unless you have worn the rotors well beyond their recommended limit of 22.6mm, you have SC or 911 rear M calipers(which is what you should have there)
Bill Verburg
Old 09-03-2006, 09:55 AM
rs6er's Avatar
The rotors are just under 20mm.
John
Old 09-03-2006, 10:01 AM
So it looks like you have worn SC rotors, the wear limit is 18mm, the machined limit is 18.6mm
Bill Verburg
Old 09-03-2006, 10:04 AM
Used Up User
imcarthur's Avatar
A late Carrera (1987) rear caliper.
Ian
'87 Carrera Cab
Old 09-03-2006, 11:23 AM
