3.8 RSR fanbelt/pulley setup...
A friend of mine has bought a RSR single belt setup for the 3.8 engine he's building
But is seems to be incomplete...
Does anyone here have pics or a scematic of these parts?
Just so we can figure out what is missing exactly
Thanks!
Old 09-25-2006, 02:41 AM
Bill Verburg's Avatar
There are 2 different set ups.
Serpentine
RS
Assuming you are talking RS, these are the parts needed.
The single pulley is only applicable for 993 engines.
Bill Verburg
Old 09-25-2006, 04:49 AM
84toy's Avatar
Bill, those look like Porsche parts or at least the fan hub. Is the pulley a Porsche item too? If yes, what is the diameter? I'm buildiing a 3.6 and was going to use the PMS setup.
Paul S
"Those who say it cannot be done should not interrupt the people doing it"
Old 09-25-2006, 06:42 AM
Both are oem production Porsche RS parts.
The PMS set up uses a different setup w/ a serpintine belt, very expensive. Clewett has a similar system
Bill Verburg
Old 09-25-2006, 08:58 AM
Insert Tag Line HERE.....
rattlsnak's Avatar
It cost me @$0.00 to build one myself. Went to a local welding company, they gave me a 4" alum solid rod 5 inches long.(scrap), measured it, cut it down on a lathe, and drilled 3 holes for the screws and one center hub. Worked perfectly, and is stll working 5 years later! (of course this was long before other people made kits, and I didnt know about the factory setup!)
Marc
Old 09-25-2006, 09:27 AM
he mentioned there was a spanner wheel included, so I guess it's the serpentine set up
WWW.9GEAR.NL
Old 10-08-2006, 03:57 PM
Sports Purpose 911 Driver
mjshira's Avatar
that sounds like maybe a clewett part? maybe patrick?
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 10-08-2006, 04:07 PM
Me like track days
Craig 930 RS's Avatar
Clewett - on a friend's 3.6:
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 10-08-2006, 04:12 PM
