Banned
Installing 86 dash in an SC??? Help, please?
There was a post back about a yr ago about putting a 86 or newer dash into a SC or older car and I cant find it. Any one here done it or know of someone who has?? I could sure use some advice. lol. Mark
The dash was changed in 1986. The vents are bigger in the center and on the sides. You will need those vent pieces as well. (I have some of them).
'75 914-6 3.2 (Track Car) '81 SC 3.6 (Beast) '993 Cab (Almost Done Restoring) |
I also plan on doing this swap ...
Frank 1980 SC Cab Conversion (sold) 1974 914 2.0 RIP rear ended Looking for a 996 Silver Cab 2002-2004 |
Banned
Help!!!
1.367m later
except for the larger center vent everything is pretty straight forward. Remove the old one, clearence center vent, install new, sit back.admire work, drink a beer.
non velox ad propitiare, verisimile non oblivisci If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR. |
Back in New England!
Another small thing; well depending on how you look at it. You most likely will have to remove you windshield and dash pad as well to do the swap.
-Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip! |
Banned
Kevin, and Matt or Jim, Have you guys done this dash swap?? Also, I want to use the dash part that is directly under the top dash pad too. Anything to know there about removal or install?
Jim, Ive got a donor car for all metal and dsh parts. Thanks, Mark |
