3.2 Header Size
I'm finding conflicting information on the best header size for a 3.2. Basically stock other than the exhaust and chip.
Does anyone know the size of SSI's or '74 and earlier HE's? 1 1/2, 1 5/8 or 1 3/4? Race car application. TIA, John
1985.5 944 GTS |
GFCC
For track applications on a 3.2 you should use 1 3/4 headers.
Got the strut brace. Thanks.
Jeff 1976 911 Coupe w/ Euro 3.0 - Sold 1987 Carrera Coupe - Sold 1999 Carrera Cabriolet - Current |
SSI primaries are 35mm(1 3/8")ID, for street use you would want ~42mm(1 1/2")ID, for a full race motor ~44.5mm(1 3/4") ID
Does SSI have a website, i would like to know how Much 1 3/4s heat exchangers would cost????
Have you ever felt suffocated while watching the Oxygen Channel? People with excuses fail. As soon as I OK my actions with an excuse, I cease bettering myself. 88 Carrera |
Guest
Posts: n/a
Sold by our host. I think they have specs.
Yes, but looking for more specs. maybe some photos.
According to Richard at PMO the header size is based on whether your using a muffler or straight pipes. On my 3.4 race motor using 50mm PMO's he suggested a 1 5/8" with a muffler and a 1 3/4 - 1 7/8" with straight pipes.
You should consider using the 993 heat exchangers instead of the SSI's, if you want heat in the race car. Tyson has a post discussing the advantages.
Harold '79 930/DP935 (sold) '68 VW 3.3 Turbo Crewcab |
MBruns for President
Primary tube size
SSI 38mm OD/ 35mm ID GHL 41mm OD/ 38mm ID B&B 41mm OD/ 38mm ID (small tube) B&B (964 version) 44.5mm OD /41mm ID (large tube) too big for a street 3.2 SC/RS 42mm ID
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Ah, this is useful!
for those who dont know, I have an Andial 3.7L motor. I think ( but am not sure) i have stock 3.2 exhaust? (just a little pinch) So, i was looking at either BB 964 or 993 HEs. But dont the 993s have the exhaust studs rotated 90degrees? Was the stock Carrera 3.2 and the stock 964 exhaust the same?
I am actually thinking of selling my 964 B & B heat exchangers and MK muffler -
Hmmmm....contact me offline.
pmajka AT shiraz.dynip.com
JermyD, I sent you a PM
84 911 Euro 3.6 liter |
here's what Ben (M&K) is doing for me.
993 HE's flipped, 2/1 s/s muffler:
cheers, Phil 84 ROW Carrera (guards red), A/C delete, Fuchs 7 + 8 x 16, Koni Adj. F+R, sway bars 20F 22R. turbo tie rods, Strut brace, brake cooling kit, C/F Recaro GT3 copies. |
Here are the 964 B & B headers
