Too much front brake- need different pads front and rear?
I'm having a problem with early front wheel lockup, and I'm hoping someone can suggest brake pads to fix the issue.
The car is a 2300 lb RS look with 930 brakes, an SC type master cylinder, no proportioning valve, and stock porsche brake pads all around. The car has a 993 motor in back, which makes it pretty rear heavy. I'm locking both fronts up quite early in street driving and at the autocross, and I haven't found any other problems with the brakes. I was thinking I'd try and fix the issue by putting higher friction brake pads in the rear. To that end, I'm looking for pads that work well cold and at low temperatures that would give me more rear brake than front. Any suggestions? Based on the following links, I was thinking maybe the Pagid RS4-2-1 (black) front and RS 4-2 (blue) rear might work, but if you look at the data it's a bit contradictory. http://www.needforspeed.co.uk/htmlpages/techBRP03.htm http://www.pagidusa.com/pagidracing/techinfo.html#frictiongraph http://forums.audiworld.com/s4/msgs/1915589.phtml Any ideas? I have used RS-19 (yellow) and RS-14 (black) front and rear in my last car, but they really need to be up to temp to work correctly- not ideal for autocross. |
if i was in the same situation as you i would add a adjustable proportioning valve . i doubt if you will get the results needed out of brake pads plus the added wear on brake rotors with agressive pads. race pads work well in track day /de events but on the street you cant get them hot enough to bite. i would think that a proportioning valve would actually be cheaper than pads with just a little more work involved.
a p/v does absolutely no good when the fronts are locking first check you alignment, don't go overboard on neg. camber in the front Hopefully you have at least a 225 tire in the front? an lsd helps a lot, 40/60 or 40/70 if you track a lot a final tweek is to use diffewrent pad compound f/r, for example Pagid RS19 yellow front and RS 14 black in back.
Alignment and corner weights are good. 225s front, 245s rear, toyo RA1s. It has a limited slip...
So I'm down to pads. As I said, I've used RS19s front with RS14s back on my last car, but you just can't get the heat in them to work well for street/ AX. I used to drag the brake getting to the starting line... I think I need to find split friction level pads that work at lower temps; some must exist...?
69 w 997 GT3 3.6L |
Listen to Bill. The M/C neds to be upgraded to a 23mm from the 930 era. The 930 caliper pistons are too large for a 19mm M/C to effectively handle.
1985.5 944 GTS |
I had the same problem which I solved by reducing my negative camber in front as close to 0 degrees as possible. What was really scary with all that camber was how easy it was to lock them up when the road got wet. Cheers, Joe Last edited by stlrj; 10-26-2006 at 11:49 AM.. |
I'm checking on the master cylinder- it's possible the PO replaced the master cylinder as well. It certainly doesn't feel like a soft pedal.
0 front camber comes at a heavy price in cornering and tire ware...
69 w 997 GT3 3.6L |
I'm sure that there are many split coefficient pad sets, I am mostly just familiar w/ Pagid
for better cold maybe try RS4-2-1 black front and RS19 yellow in back. The RS4-2-1 are not going to be very good for a lapping day, but both work well cold w/ the RS19 will always have relatively better friction by the same amount in the back. So you get predictable performance at all temps and better friction in the back. I wouldn't go to zero camber just don't go as crazy as some of the track guys like to.
My car is completely stock and, I don't know about your cars but, my front always much stronger than the rear. Many agressive braking locked up the front. Front tires slide, smoke everywhere but the rear acted as nothing.
Fat butt 911, 1987 |
Slippery Slope Victim
I've got 930 brakes on my 2460 lb SC and I feel I have early front lock up as well, has not happened on the track yet but in a "almost panic" stop the fronts lock up seemingly too fast.
I am running a 23mm 930 MC and Padgid orange all around. PS.they squeal like a MF on the street. I'm swapping out to a regular street pad for non track use.
Mike² 1985 M491 |
Same boat/issue. 930 brakes on an SC, with the turbo MC and the fronts lock up, it seems like, way early. Can you use an adjustable pv on the front circuit to even it up some?
1981 911 SC 7 & 9 Fuchs, monoballs, 22/27 t-bars, 19/22 swaybars, M&K dual in/ dual out |
Me like track days
He has the 23mm MC.
For AX only, I'd try the oranges in front and blacks in the back. Your rear friction levels would be nice & high - even when cool compared to the oranges that came with your car when you got it. Let this be your guide:
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
Thanks for the input. One thing has me confused: The graph in Craig's post above is the same as the 2nd link I'd found, but I notice that the table below doesn't agree at all, giving orange and RS14 black very similar friction levels at higher temperatures (this is from the first link)...
![]() Is one out of date or wrong? Also, no issue mixing carbon and ceramic based pads? I may try Orange front pads with stock rear pads. All this data seems to suggest that will make things worse, at which point I'd try the blacks in the back (and go back to waking the dead with brake noise on the street). |
If you you look at the RS 4-2-1 vs the RS 19 you can see that they are almost pareallel. Thats good, consistant response not matter what the temp. I wouldn't use RS4-4 w/ RS 19 or RS 4-2-1 because there wil be a diffewrent respoinse at low and hight temps. another possibility for A/X would be RS4-2 front and RS 4-4 rear, same thing, parallel response curves but less of a differential between them. Never ever put a p/v on the front, the results are frightening.
Me like track days
Did some research:
For AX - a rear PV would be your best bet. Stay with RS44s F&R
Craig- But I'm locking the fronts already, so a rear pv wouldn't help much...
Bill- Look at the RS4-4 and RS 14 data at 300C on the table- almost equal friction. If you check the graph at 300C they are no where close... They can't both be right.
69 w 997 GT3 3.6L |
I would believe the graphs
I'm with Bill
I was having front lock up issues with a different type of car that is light weight nad has lots of power. I was not having this issue on the track only in Autocross.
The biggest part of my problem was me. I was pushing the car past its limits. I was asking too much from it. Once I smoothed out and picked better braking points along with better turn in points my lockup issue is non-existant. All of this smoothness enabled me to consistantly score Fast Time of the Day at almost every event with an AP class Cobra being the one to spoil that for me. I am not saying you do not have issues with the car but in some cases when everything has been checked and double checked, maybe its time to check the nut behind the steering wheel.
1978 Mini Cooper Pickup 1991 BMW 318i M50 2.8 swap 2005 Mini Cooper S 2014 BMW i3 Giga World - For sale in late March Last edited by Jims5543; 10-27-2006 at 05:27 AM.. |
Me like track days
Sounds like you'll have to do track events..... rather than autocross!
