Student of the obvious
LeeH's Avatar
Unhappy Time, tools, and skill required to replace bent valves?
My 80+ mph downshift to second (instead of upshift to 4th) at the track yesterday has left me with the symptoms of bent valves.
The engine only has around 4000 miles on a rebuild. What's it going to take to get the car back on the road?
Lee
Old 11-19-2006, 02:27 PM
Early_S_Man's Avatar
Porsche Crest
Found any broken rockers?
If you have all of the necessary parts and tools on hand ... one weekend [two-day] job at leisurely, careful. methodical pace:
Day 1 -- remove engine, disassemble & clean up parts, evaluate the damage ...
Day 2 -- replace bent/broken stuff, reassemble, time cams, reattach induction & exhaust, reinstall engine.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 11-19-2006, 02:42 PM
I would say it is practically much longer than 2 days. You would not know what you have to buy until you are finished ripping it apart. It would then take you at least a week to get the parts, and then 2 more days to put the whole thing back. My guess, is 10 days.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 11-19-2006, 04:40 PM
I would never install any new valves without grinding the 3 angles and checking them for concentricity.
As yelbcab1 said, this is not a 2-day job unless you are a shop and do ALL of your own machine work in-house like we do.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 11-19-2006, 06:10 PM
Irrationally exuberant
ChrisBennet's Avatar
What about the rod bearing on the cylinders that bent the valves?
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 11-19-2006, 06:15 PM
FenderGuy's Avatar
Lee
sorry to hear about your engine troubles
Frank
1980 SC Cab Conversion (sold)
1974 914 2.0 RIP rear ended
Looking for a 996 Silver Cab 2002-2004
Old 11-19-2006, 09:59 PM
Jeff Alton's Avatar
This requires some serious inspection. Chris is right in asking about the bearings. I rebuilt a 3.6 that had 6 bent valves. The adjustment screws in the rockers were also bent. Oh and it cracked two guides as well. Steve rebuilt the heads for me with all new valves and guides. I had the rockers magnafluxed too. The valves had just "kissed" the pistons as you had to look very very very close to see any markings on the pistons.
Cheers
www.turn3autosport.com
Old 11-19-2006, 10:11 PM
len911's Avatar
Been there done that! I ended up replacing 6 exhaust valves and doing a complete valve job a few years ago. Just upgraded to a Rennshift shifter. Too late for you, but I have a Robotek listed in the for sale section... Cheap insurance... Lou
'76 911 "Moneypenny" daily driver
'74 911 "JLo" IROC DE Car
'03 CRV, '02 Jeep Grand Cherokee
'03 Holiday Rambler Admiral SE, 30ft, 8.1l, 340HP, 455Ft#
http://www.nicotra4.hpshare.net/BasketCaseMotorsports/
Old 11-20-2006, 04:39 AM
What?!?!
DonDavis's Avatar
Sorry 'bout that, Lee. You know I'll be there and I'll bring my engine stand. Use it as long as you like.
running shoes, couple tools, fishing pole
1996 Subaru Legacy Outback AWD, 5speed
2002 Subaru Impreza WRX, 5speed
2014 Tundra SR5, 4x4
1964 Land Rover SII A 109 - sold this albatross
Old 11-20-2006, 06:23 AM
GFCC
Jeff's Avatar
+1, except for the engine stand part.
Jeff
1976 911 Coupe w/ Euro 3.0 - Sold
1987 Carrera Coupe - Sold
1999 Carrera Cabriolet - Current
Old 11-20-2006, 06:27 AM
FenderGuy's Avatar
+2, I don't know how much I could do, but eager to learn
Frank
Old 11-20-2006, 08:18 AM
Az911's Avatar
Send a message via AIM to Az911
Lee I can help you with the engine drop I've done it before and it's easy.
Also time to buy my wevo shifter to keep this from happening again.
72T RS look
96 993
Old 11-20-2006, 08:22 AM
Super Moderator
cstreit's Avatar
I'll typically do valve guides on bent-valve engines. More often than not, the valve guide is damaged. Possible piston damage, they'll need to be checked...
...and depending on how bad the over-rev was, rod-bolts may be suspect. You can often tell by how bad the divots are in the pistons...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 11-20-2006, 10:31 AM
LeeH's Avatar
I bought a compression test kit today. I did the test cold and without the aid of the long adapter.
The number were:
60, 120, 80, 0, 0, 5
I wonder if I'm not getting the threads seated well enough since I'm just twisting the braided hose to tighten the adapter into the spark plug hole. It's hard to believe that the engine would run at all with these numbers. It actually ran OK above 2000 rpm.
Lee
Old 11-20-2006, 06:43 PM
Lee
Hand tightening is enough for this test. Trust the numbers, you are toast. One bent valve is as bad as 6, because the engine has to come out.
Good luck with it.
Old 11-20-2006, 06:56 PM
LeeH's Avatar
Oh c'mon... let me briefly fantasize that it's only my lack of experience using a compression tester that caused these number and not my poor shifting at the track!
Lee
Old 11-21-2006, 06:40 AM
Hi Lee,
I did exactly the same thing as you - trying for fourth and got second at high speed. It took me a little while to fix because I was a complete novice mechanics wise, but everything went fine - I found no broken rockers or damaged pistons - just 6 bent exhaust valves. It was all a very worthwhile experience for me because I learnt loads and now don't fear working on my car. I recommend it.
Charles
'84 911 3.2
Old 11-21-2006, 09:04 AM
Slumlord
Porsche_monkey's Avatar
My throttle stuck and I did the wrong thing...
Took me several months, but I re-did the entire engine. You might find that once you get into it, you want to be sure it's 100% done.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 11-21-2006, 01:10 PM
len911's Avatar
It happens.... I missed 4th and went into 2nd at VIR about 5 yrs ago. Figure I spun the eng to about 9K. Ouch! Here's proof, six drunken sailors ... Worst part was that I did it on my first run. Wife was ticked since she could not drive for the rest of the weekend. Lou
Old 11-21-2006, 01:19 PM
LeeH's Avatar
Originally I was going to have all you guys in Phoenix come over for the drop. I had a little time this afternoon and it's pretty much all over except for the four big bolts. Anybody in Phoenix is welcome to stop by for the actual drop Saturday a.m. I'm in Ahwatukee. 602-300-0309
Lee
Old 12-08-2006, 09:43 PM
