Throttle Position Sensor on a Carrera
How can you get the Throttle Position on a Carrera?
I am planning on getting a data logger and would like to record Throttle Position. I think it only has a switch for WOT and Idle, but nothing inbetween. Is that correct? If so how could I go about hooking up a Throttle Position Sensor on a Carrera? Any recommendations? Thanks. -Scott |
I would rather be driving
Here is a link for a TPS on an SC. Tony Bitz did this for his EFI conversion. You could do something similar.
http://www.geocities.com/tbitz/throttle_body.html
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
I *think* you can adapt a 944 or later model variable pot-style TPS on the Carrera throttle body, but only as an aftermarket add-on... it won't work with the OEM DME. You'd need a DME/ECU that understands 0%-100% throttle conditions, not just on/off.
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
String potentiometer?
Bosch 0 280 120 400 which I believe is off of a 944 turbo and has a potentiometer (POT) function as well as an integrated idle switch. This is what I purchased from Clewett Engineering to place on a 3.2 throttle body for my EFI conversion. It seems to be a good fit for the TB but will not interface with the carrera DME.
Steve Sapere aude 1983 3.4L 911SC turbo. Sold Last edited by sjf911; 02-15-2007 at 06:25 PM.. |
I used a '95 993 TPS, it fits the shaft perfectly and all I had to do was make an adapter plate to screw onto the side of the TB and bolt the tps to it. I have the standard ignition part numbers you need if you want. I think it cost around $80.
75 911 Indian Red- RUFWAN2B 2000 Boxster 2000 & 2007 Dobies www.stahlwerks.com Cages and preparation for your Porsche “People who never make mistakes must get tired of doing nothing” Bill : The origin of the orgy of Porsche |
